POV-Ray : Newsgroups : povray.general : Radial specialists wanted Server Time
11 Jun 2026 07:24:34 EDT (-0400)
  Radial specialists wanted (Message 1 to 4 of 4)
Subject: Radial specialists wanted
Date: 21 Feb 2005 11:06:05
Message: <421a06ed@news.povray.org>
I don't understand how radial works with non integer frequencies.
Let's take a simple one :
#declare MyP = pigment{ radial
         frequency F
         phase P
         pigment_map {
                [0.5 Black]
                [0.5 White]}}
I want F to grow from .1 to 10, and I want the Black color to start at the
fixed position (+x, -z, I don' t care). What is the value of P which achieve
this ?
It looked simple to me at first, but I must say that I going to give up. Any
one can help ?
Subject: Re: Radial specialists wanted
Date: 21 Feb 2005 13:00:46
Message: <HFHyuAA6GiGCFwiB@econym.demon.co.uk>
>         frequency F
>         phase P
>         pigment_map {
>                [0.5 Black]
>                [0.5 White]}}
>this ?
>one can help ?
I couldn't get radial itself to behave predictably for non-integer
frequencies, but I've managed to write a pigment function that behaves
in a predictable manner and gives the same results as "radial" for
#include "functions.inc"
         function {F * (0.5+f_th(z,0,-x)/2/pi)}
         pigment_map {
                [0.5 Black]
                [0.5 White]}}
The "/2/pi" bit compensates for the fact that f_th() returns radians.
The "0.5" compensates for the fact that the implied atan operation
returns negative values in the second hemisphere. We want values between
0.0 and 1.0 rather than between -0.5 and +0.5.
Using "(z,0,-x)" instead of "(x,0,z)" flips the axes, so that the
pattern starts at +x and goes clockwise, like "radial" does, rather than
starting at -z and going anticlockwise.
Note that you won't always see a black/white transition at +x, because
for some values of F the pattern ends on black, and you can't see where
the end black ends and the start black starts. (Similarly, for negative
values of F you can get two whites next to each other).
If you animate with "#declare F=clock*10;" you can see how the starting
point behaves.
Don't try using "phase" to change the starting point because it
interferes with the "0.5" compensation factor.
Mike Williams
Gentleman of Leisure
Date: 22 Feb 2005 04:32:08
Message: <421afc18$1@news.povray.org>
Thank you Mike to share your findings. It is like fresh air coming from a
door that I did not realize it existed.
I like your idea of getting rid off native radial (see my comments below).
You get similar results to my best shot so far, which is :
         frequency F
         phase -(F/4+F+.5)
         pigment_map {
                [0.5 Black]
                [0.5 White]}
The black starts nicely at -z going
anti-clockwise, except when F becomes N+]0,0.5[ . Then the start shifts
continuously and join -z again when F becomes N+0.5. And it stays there
until N+1. etc... This is annoying !!
Your solution has the exact same behavior (minus orientation) as mine but
looks to be much more open
to dedicated tuning. I will explore.
My current point of view is that radial pattern feature has a serious flaw
or even bug?. At least everybody will admit a severe weakness of the
documentation which states : "Values from 0.0 to 1.0 cause a fraction of the
map to be used."
I keep you posted if I find a decent solution
Comparison can be rendered with :
#include "colors.inc" #include "functions.inc"
camera {orthographic angle 90 location <0,2.5,0>
        right x*image_width/image_height look_at <0,-4.7,0>}
light_source{< 0, 30, 0> color White shadowless}
plane{ <0,1,0>, 0 texture{ pigment{color rgb <0.7,0.5,0.3>}}}
#macro Draw(Max)
#local J=0;
  union {
  #while (J<6)
     #local I = 1;
     union {
        #while (I<Max)
                text {ttf "timrom.ttf" str(I/2+J/10,3,1), 1, 0 scale .2
                        pigment {Yellow} rotate x*90 translate
<I-Max/2+.3,1,-.3>}
                cylinder {0,y,.3 pigment {R(I/2+J/10)} translate
x*(I-Max/2)}
                #local I = I+1;
        translate -z*(.8*J-4) }
    #local J=J+1;
#macro R(F) // RADIAL
#local Tmp = pigment{radial
         frequency F
         phase -(F/4+F+.5)
         pigment_map {
                [0.5 Black]
                [0.5 White]}
         rotate y*90
Tmp
object {Draw(14)}
#macro R(F) // FUNCTION
         function {F * (0.5+f_th(z,0,x)/2/pi)}
         pigment_map {
                [0.5 Black]
                [0.5 White]}
Tmp
object {Draw(14) translate -z*5}
HFH### [at] econymdemoncouk...
>>         frequency F
>>         phase P
>>         pigment_map {
>>                [0.5 Black]
>>                [0.5 White]}}
>>achieve
>>this ?
>>Any
>>one can help ?
>         pigment_map {
>                [0.5 Black]
>                [0.5 White]}}
> point behaves.
> Mike Williams
Date: 22 Feb 2005 06:23:50
Message: <ZmnFmAA5YxGCFwS5@econym.demon.co.uk>
>         frequency F
>         phase -(F/4+F+.5)
>         pigment_map {
>                [0.5 Black]
>                [0.5 White]}
But, as I said, that's simply because the end colour is the same as the
start colour. The colouring starts in the same place, but you can't see
the colour transition.
If you temporarily change it to
         pigment_map {
                [0 Black]
                [1 White]}}
then you can see what's happening more clearly.
Mike Williams
