POV-Ray : Newsgroups : povray.general : Problem using inside() with prism Server Time
22 Nov 2025 05:14:38 EST (-0500)
  Problem using inside() with prism (Message 1 to 2 of 2)
Subject: Problem using inside() with prism
Date: 19 Feb 2005 12:10:54
Message: <4217731e$1@news.povray.org>
There seems to be a bug when testing inside() with some prisms and a point
on the bisector of an angle, where the bisector is the x-axis, but I
haven't found any report on this. The following code should demonstrate the
problem:
   #default{finish{ambient 1}}
   camera {orthographic location 4*y look_at 0}
   background {color Gray50}
   #declare Bound =
   prism {
      linear_spline
      -1, 1, 3,
      //These don't work
      //<-1, 0>, < 1, 1>, < 0, 0>, < 1,-1>, <-1, 0>
      //< 1, 1>, <-1, 1>, < .5, 0>, <-1,-1>, < 1,-1>
      <-1, 1>, < 0, 0>, <-1,-1>
      //<-1,-1>, < 1, 0>, <-1, 1>
      //This one works as expected
      //< 1, 1>, < 0, 0>, < 1,-1>
      //rotate 360*y
   object {Bound pigment {color Blue}}
   #declare j = -10;
   #while (j < 10)
      #declare i = -10;
      #while (i < 10)
         sphere {
            <i, 1, j>, .02
               #switch ( inside(Bound, <i, 0, j>) )
                  #case (0) color Red #break
                  #case (1) color Green #break
                  #else color Yellow #break
         #declare i = i+.25;
      #declare j = j+.25;
When I render this on PovWin 3.6.1a the spheres along the x-axis are all
but one red even where the tested points are clearly inside the prism and
should be green. The other prisms have similar problems and I can't
reproduce this behavior along the z-axis. After rotating the prism object
by 360 degrees around the y-axis, the inner spheres colors are correct. Can
anyone confirm this?
I'm using Windows 2000 SP4 on an Intel P4 @ 1800 MHz with 512MB.
Subject: Re: Problem using inside() with prism
Date: 19 Feb 2005 13:38:06
Message: <4217878e$1@news.povray.org>
The prism insidedness test probably uses a trick that looks at how many
edges are to the left or right of the point being tested, and checks if that
number is odd. If there's a vertex of the prism along that line, then it
might not work right. So try translating the prism a tiny bit along the z
axis.
 - Slime
 [ http://www.slimeland.com/ ]
