![](/i/fill.gif) |
Is this an example of Isosurface Image Noise Problem?
Referring to this FAQ,
http://tag.povray.org/povQandT/languageQandT.html#isosurfacebug
I wonder if my Isosurface code below fits the above description.
I'm having sudden black lines here and there...
I would agree that using Predefined shape code would solve my entire
problem, however I'm required to render in Isosurface code, so no
shortcuts.
[Isosurface Code]
#include "functions.inc"
global_settings
assumed_gamma 1.0
camera
location <0.0, .5, -4.5>
direction 1.5*z
right 4/3*x
look_at <0.0, 0.0, 0.0>
light_source
0*x // light's position (translated below)
color red 1.0 green 1.0 blue 1.0 // light's color
translate <-30, 30, -30>
/*sky_sphere { pigment {
function{abs(y)}
color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
/* #declare R = 0.5;
isosurface {
function { x*x + y*y + z*z - R*R }
max_gradient 4.4
//contained_by{sphere{0,1.2}}
//interior{ior 1.5 dispersion 1.05}
pigment {rgb .9}
finish {phong 0.5 phong_size 10}
//#declare C = 0.215;
/*isosurface {
function { -(0.215-pow(x,2)-pow(z,2)) }
threshold 0
accuracy 0.001
max_gradient 4.4
//contained_by{sphere{0,2}}
pigment {White}
finish {specular 1}
difference{
merge
// Cylinder Middle
isosurface {
function { pow(x,2) + pow(z,2) - pow(0.215,2) }
accuracy 0.001
threshold 0
max_gradient 4
contained_by{box{<-1,-0.5,-1>, <1,0.5,1>}}
texture{pigment {White filter 0.7} finish{specular 1}}
//Sphere Top
isosurface {
function { pow(x,2) + pow(y,2) + pow(z,2) - pow(0.5,2) }
accuracy 0.001
threshold 0
max_gradient 4
translate <0, 0.78, 0>
//Sphere Bottom
isosurface {
accuracy 0.001
threshold 0
max_gradient 4
translate <0, -0.78, 0>
// Cylinder Top
isosurface {
function { pow(x,2) + pow(z,2) - pow(0.5,2) }
accuracy 0.001
threshold 0
max_gradient 4
contained_by{box{<-1,0.78,-1>, <1,1,1>}}
// Cylinder Bottom
isosurface {
accuracy 0.001
threshold 0
max_gradient 4
contained_by{box{<-1,-0.78,-1>, <1,-1,1>}}
/* isosurface {
function { f_torus (x,y,z,0.385, 0.37) }
//accuracy 0.001
//threshold 0
max_gradient 4
contained_by{sphere {0,0.5}}
//torus{0.385, 0.37}
//texture{pigment {White filter 0.7} finish{specular 1}}
#declare r1=0.385;
#declare r2=0.37;
poly
{ 4,
<1,0,0,0,2,
0,0,2,0,-2*(r1*r1+r2*r2),
0,0,0,0,0,
0,0,0,0,0,
1,0,0,2,0,
2*(r1*r1-r2*r2),0,0,0,0,
1,0,-2*(r1*r1+r2*r2),0,pow(r1,4)+pow(r2,4)-2*r1*r1*r2*r2>
[/Isosurface Code]
[Predefined Shape Code]
global_settings
assumed_gamma 1.0
camera
direction 1.5*z
right 4/3*x
light_source
difference
merge
cylinder{<0,-0.5,0>, <0,0.5,0>, 0.215}
sphere{<0, .78, 0> 0.5}
sphere{<0, -.78, 0> 0.5}
cylinder{<0, .78, 0>, <0, 1, 0>, .5}
cylinder{<0, -.78, 0>, <0, -1, 0>, .5}
torus{0.385, 0.37}
[/Predefined Shape Code]
![](/i/fill.gif) |
