POV-Ray : Newsgroups : povray.general : Parameters to functions used in expressions ... Server Time
16 Aug 2025 00:12:56 EDT (-0400)
  Parameters to functions used in expressions ... (Message 1 to 5 of 5)
Subject: Parameters to functions used in expressions ...
Date: 18 Jan 2005 23:41:49
Message: <41ede50d@news.povray.org>
Folks,
I am still learning functions ... I wanted to create something like:
#declare foo = function(a,b,c) {
   #if (a>0.0)
      #declare a=a+1;
a+b+c
My problem seems to be that the formal parameters supplied to the function
don't seem to be in scope for the expressions.  It is as thought they were
not declared.  When I try and run this, I get:
File: C:\Documents and Settings\kolban\My Documents\My
3D\Projects\Tiles\test.inc  Line: 2
#if (a <----ERROR
Parse Error: Expected 'numeric expression', undeclared identifier 'a' found
instead
Returned from renderer with error status
Am I not allowed to use function parameters in the conditionals within my
function body?
Neil
Subject: Re: Parameters to functions used in expressions ...
Date: 18 Jan 2005 23:59:04
Message: <41ede918$1@news.povray.org>
> not declared.
They aren't. Commands beginning with # are evaluated at parse time in order
to get the tokens which are used to generate the objects they surround: in
this case, the function. So as the # commands are evaluated, the function
doesn't exist yet, and once the function is finished being created, the #
commands are already taken care of and are never seen again.
If you want to have an "if"-type structure within a function, you can use
the select() function (untested code):
    select(a,
        (a+1)+b+c, // if a >= 0
        a+b+c // otherwise
See the documentation for more thorough information on select().
Also note that you can't define temporary variables within a function (that
is, there's no equivalent for #declare). You can, however, call other
functions and pass them whatever you want, which is often a decent
replacement:
#declare bar = function(a,b,c) {
    a+b+c // or something more complicated
    select(a, bar(a+1, b, c), bar(a, b, c))
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Jan 2005 03:33:31
Message: <41ee1b5b$1@news.povray.org>
>>not declared.
Do arrays work in the same way ? I recall having tried to get a value in
an array, indexed by a parameter of a function (something like
function(x) {myarray[floor(x)]} ) and never being able to find a way to
do so...
Vincent
Date: 19 Jan 2005 09:09:22
Message: <41ee6a12$1@news.povray.org>
> do so...
Yes; since array elements are evaluated during parse time, the index of the
array can't be dependant on function arguments which would only be available
when the function is evaluated. The number within the [] brackets must be
something that can be evaluated ahead of time, and then the function will be
equivalent to function(x) {3} or something like that.
(There are ways, however, to construct a function from an SDL array that
will work essentially like a lookup on the array. Unfortunately, the lookup
will be at best an O(log(n)) search instead of an O(1) lookup, and the
function will take more memory than the original array itself.)
 - Slime
Date: 19 Jan 2005 11:13:28
Message: <41ee8728@news.povray.org>
>>do so...
>  - Slime
OK, thanks for the insight !
Vincent
