POV-Ray : Newsgroups : povray.general : Function based patterns ... value returned from function ... Server Time
1 Mar 2026 07:25:00 EST (-0500)
  Function based patterns ... value returned from function ... (Message 1 to 6 of 6)
Subject: Function based patterns ... value returned from function ...
Date: 18 Jan 2005 23:21:15
Message: <41ede03b$1@news.povray.org>
Folks,
I was having a go at updating our wiki on an area I am studying ... function
based patterns ...
http://www.wikipov.org/ow.asp?FunctionBasedPatterns
As I started writing what I thought I knew, a question struck me that I
think I need some help with.
If I declare a function foo(x,y,z) ... then this function is going to return
a float calculated from x, y and z.
And this is where I get confused ...
If the value returned is between 0 and 1 .... 0.0 <= value <= 1.0 then I see
how that can be applied to a color map to generate an appropriate color.
But what about values outside of the color map range ... what of values <
0.0 and > 1.0 ... how do they get mapped to a color value?
I am going to guess that the integer portion is thrown away ... but that is
a guess ...
so
2.73   -> 0.73
199.2 -> 0.2
-56.6 -> 0.6
But this is a guess ...
Neil
Subject: Re: Function based patterns ... value returned from function ...
Date: 18 Jan 2005 23:52:42
Message: <41ede79a$1@news.povray.org>
is
> a guess ...
Pretty much. One of your examples was wrong:
> -56.6 -> 0.6
-56.6 -> 0.4
Use the equation x - floor(x).
(Although I think 1.0 maps to 1.0, so x - floor(x) might not be exactly
accurate.)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Jan 2005 05:54:31
Message: <41ee3c67@news.povray.org>
  Why don't you simply test it?
  AFAIK pattern values beyond those limits get clipped. That is, everything
larger than 1 is converted to 1 and everything smaller than 0 is converted
to 0.
Date: 19 Jan 2005 06:00:59
Message: <41ee3deb$1@news.povray.org>
Neil Kolban nous apporta ses lumieres en ce 2005-01-18 23:21:
> Folks,
> based patterns ...
> a guess ...
> so
> 2.73   -> 0.73
> 199.2 -> 0.2
> -56.6 -> 0.6
> Neil
I think that you'll have to use some math to reduce it to the 0..1 range. Values over
1 or under 0
will show as 1 or 0 in a normal scene. The colours <1,234.2,-0,5> and <1,1,0> render
the same. If
you use radiosity, it can have a big effect on your results.
Date: 19 Jan 2005 08:49:12
Message: <445GyHAJVm7BFwjB@econym.demon.co.uk>
>> Folks,
>> based patterns ...
>> a guess ...
>> so
>> 2.73   -> 0.73
>> 199.2 -> 0.2
>> -56.6 -> 0.6
>> Neil
>over 1 or under 0
>render the same. If
Colours and pattern values are different things. Pattern values get
reduced into the range 0 - 1 for you before being converted into
colours.
It's easy to test that these two boxes are identical, and remain
identical if you add the same colour_map to them.
box {-1,1 pigment { function {0.4}}}
box {-1,1 pigment { function {-56.6}}
  translate x*2.1
Mike Williams
Gentleman of Leisure
Date: 19 Jan 2005 14:49:33
Message: <41eeb9cd@news.povray.org>
Hash: SHA1
http://www.povray.org/documentation/view/3.6.1/404/
	Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFB7rnMqIYJdJhyixIRAv91AJ40CDq+f7ctXchvMh3tiS329XWFhgCgrKTK
d8SiZP8o2ZHFzH1bZ2CPCjU=
=a9VU
-----END PGP SIGNATURE-----
