POV-Ray : Newsgroups : povray.general : Problems performing trace() on object Server Time
11 Sep 2025 05:42:24 EDT (-0400)
  Problems performing trace() on object (Message 1 to 5 of 5)
Subject: Problems performing trace() on object
Date: 11 Dec 2004 20:07:39
Message: <41bb99db@news.povray.org>
I know lots of you have used trace() quite recently, so I hope you'll be
able to help me out here. :)
I have a heightfield. A big one. As in, 600x500. I want to place battle
droids (similar to the one I posted in p.b.i earlier this week) on it.
It would be nice to spread them out over about half of it in on the
z-axis, if that's even possible, (but I thought I heard somewhere that
it's not) but most importantly I just want them spread over the width of
the entire field.
So I'm using trace() to position them randomly at the proper height.
That works. Very well, in fact. However, they only get spread over about
an eighth of the image - halfway across and about a quarter way down.
Here's the slightly modified code I copied from Gilles' xfrog tree
conversion page ("battlefield" is the heightfield and "droid+gun.pov" is
the file which contains the droid object definition. "Inter+y*19" is
necessary to raise the droid to the proper height above the field):
   #include "droid+gun.pov"
   #declare i=1;
   #declare rd=seed(2);
   #while (i < 25) // loop 49 droids
     #declare Norm=<0,0,0>;
     #declare Start = x*(-300*rand(rd)) + z*(250*rand(rd));
     #declare Inter= trace ( battlefield, Start, y, Norm );
     #if (vlength(Norm)>0) // If Norm = <0,0,0> no intersection is found
       object{droid rotate y*1*rand(rd) translate Inter+y*19}
     #declare i=i+1;
Is there a reason obvious to anyone why it's doing this? I can provide
the render if necessary.
Thanks,
~Mike
Subject: Re: Problems performing trace() on object
Date: 11 Dec 2004 20:32:21
Message: <41bb9fa5$1@news.povray.org>
First: Where's your heightfield placed? Centered on the origin? Because,
without scalement or translation, it ranges from <0,0,0> to <1,1,1>.
Second: The script only covers the area from <-300,250,0> to <0,0,0>, not
more. If you want it to spread from <-300,250,0> to <300,0,0>, you should
modify this line:
to this:
#declare Start = x*(-300*(rand(rd)*2-1)) + z*(250*rand(rd));
That aside, random placement of course has some issues. Even distribution
with a little random noise might work better. But that's just my 2 cents.
Tim
"Tim Nikias v2.0"
Date: 11 Dec 2004 20:35:00
Message: <web.41bb9fe127cc0c29acced0c50@news.povray.org>
Have you tried increasing the y? If you happen to be starting on the wrong
side, you'd never see the droid.
-S
5TF!
Date: 11 Dec 2004 20:40:27
Message: <41bba18b$1@news.povray.org>
Translated <.-5,.009, -.5> and then scaled <600, 75, 500>.
> modify this line:
> to this:
I didn't think of trying even distro. That'll be version 2. :)
Your line above works great, with the small exception that they seem to
be more bunched up on the left side than the right. Which is okay, I
think, but just for curiosity's sake, is there a reason for that?
Thanks a bunch, Tim!!
~Mike
Date: 11 Dec 2004 20:53:35
Message: <41bba49f@news.povray.org>
Well, there are even distro which work quite well. E.g. the following:
#declare MaxRad = 1;
#local Counter=0;
#while (Counter<=TotalAmount)
#declare Pos=vrotate(<MaxRad ,0,0>,y*(360/.618*Counter)) *
sqrt(Counter/TotalAmount);
sphere{Pos,.05 pigment{rgb x}}
#declare Counter=Counter+1;
produces a nice, even distribution, without looking like a grid.
(Here's a link for further insight into the code above:
http://www.mcs.surrey.ac.uk/Personal/R.Knott/Fibonacci/fibnat.html#seeds).
I'm not sure, but it may depend on how many times you call the rd-random
stream. AFAIK, the stream jumps back and forth between positions more to 0
and more to 1, but over hundreds of iterations, this evens out. Just try a
different seed, or, if my theory would be correct, just add a rand(rd)
before entering the #if (vlength())-case.
Another thing I've noticed: vlength() will always return positive numbers or
0, so instead of
you could just as easily write
#if (vlength(Norm)
because POV-Ray interprets 0 as false, but !=0 as true.
No problem, that was an easy one. :-)
"Tim Nikias v2.0"
