POV-Ray : Newsgroups : povray.general : Reference geometry... Server Time
11 May 2026 17:20:11 EDT (-0400)
  Reference geometry... (Message 1 to 4 of 4)
Subject: Reference geometry...
Date: 22 Oct 2004 17:39:59
Message: <41797e2f@news.povray.org>
I just played a bit with Aqsis and tested something RenderMan calls
"Reference Geometry".
It's a bit like u/v mapping, but for 3d-textures:
If you've got a mesh that deforms (in an animation), u/v mapping would
ensure that the texture stayes "attached" to the shape. But
unfortunately using a 3D procedural texture will not work in POV-Ray,
the texture would slide around on the geometry.
With RenderMan you can attach the texture to a deforming object in a way
that the pattern will stick to the surface by defining an (undeformed)
reference mesh used for texturing.
Theoretically it would be easy to do the same trick with a raytracer:
If you've got the u/v coordinates (e.g. on a bicubic patch or some sort
of mesh) of the ray intersection, use them to compute the (3d) position
on the reference patch/mesh and use that for texturing...
The quesition is: Can this be done in SDL?
Subject: Re: Reference geometry...
Date: 22 Oct 2004 18:56:36
Message: <41799024$1@news.povray.org>
Yes. There are several techniques described in this thread:
Subject: Can I bake UV textures with Povray?
Date: 20 Aug 2004 03:05:01
http://news.povray.org/povray.general/thread/%3Cweb.412569f73137e9f1406ebe00%40news.povray.org%3E/
http://tinyurl.com/5l5f4
And here's another message that might be relevant:
Subject: Baking UV textures with POV-Ray
Date: 21 Aug 2004 04:48:25
http://news.povray.org/povray.binaries.scene-files/thread/%3C4126d419@news.povray.org%3E/
http://tinyurl.com/6wrsl
Tor Olav
http://subcube.net
http://subcube.com
Date: 22 Oct 2004 22:00:07
Message: <4179bb27$1@news.povray.org>
http://www.geocities.com/pterandon2/alldancecar05d01.html
"Sascha Ledinsky" <sas### [at] userssourceforgenet> wrote in message
news:41797e2f@news.povray.org...
> But unfortunately using a 3D procedural texture will not work in POV-Ray,
Date: 24 Oct 2004 04:33:24
Message: <417b68d4$1@news.povray.org>
That looks very interesting, thanks!
However I doubt that it will work for bicubic patches. I'll have a look...
