POV-Ray : Newsgroups : povray.general : Segmentation fault Server Time
15 Jan 2026 05:49:59 EST (-0500)
  Segmentation fault (Message 1 to 10 of 19)
Subject: Segmentation fault
Date: 21 Oct 2004 12:36:09
Message: <4177e579$1@news.povray.org>
The following code snippet causes both POV 3.5 and 3.6 to exit with a
segmentation fault on my Gentoo 2.4.25, Athlon XP 2600+, 1 Gig RAM:
<POV>
#macro F_Plane ()
   #local fn_p=function (x,y,z) { y };
   fn_p
#local F1= F_Plane();
#declare fn_crash = function(x,y,z) { F1(x,y,z) }
</POV>
Can anyone confirm this behaviour?
Thanks,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Subject: Re: Segmentation fault
Date: 21 Oct 2004 12:45:22
Message: <4177e7a2$1@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:4177e579$1@news.povray.org...
> <POV>
> #macro F_Plane ()
>    fn_p
> #end
> </POV>
> Thanks,
> Florian
well it sure make 3.6 on Windows XP to act upset.
"The POV-Ray code rendering code threw an unhandled exception..." But that
was after I added a basic scene setup. Otherwise, just trying to render the
code you gave cause pov to hang.
Date: 21 Oct 2004 12:51:07
Message: <4177e8fb$1@news.povray.org>
Do you guys talk about 3.6.1 which is the latest version?
Sevei S.
Date: 21 Oct 2004 13:04:25
Message: <4177ec19@news.povray.org>
It happens for me on 3.5, 3.6.0 and 3.6.1 (the last one freshly
installed after your question).
Florian
Date: 21 Oct 2004 17:50:00
Message: <web.41782ecaca09a488188eee560@news.povray.org>
yes.
I use povray 3.6.1-fbdev-0.1.tar.gz , which is a small patch for povray to
use the framebuffer-device instead of the normal X-Display (I use a special
extension for my sis-graphicscard)
Linux-Mandrake 9.2, X.org 6.8.0
Mark
Date: 22 Oct 2004 04:30:10
Message: <4178c512@news.povray.org>
  "Doctor, it really hurts when I touch here."
  "Then don't touch there."
Date: 22 Oct 2004 07:01:47
Message: <4178e89b@news.povray.org>
If this is meant to be a joke, then fine :)
If it's no joke, then I really disagree with that attitude...
Florian
Date: 22 Oct 2004 13:43:30
Message: <417946c2$1@news.povray.org>
> It's a Groucho Marx line. We use it all the time around here.
Ah, didn't know that.
> "Every time I assign data to a version of the program too old to handle
> it, the reports come out funny."
Well, IMHO the code snippet is valid SDL. And even if that's not the
case: a segmentation fault is in no way a good idea to treat syntax
errors (Debugging POV SDL would be much more interesting if all syntax
errors were treated that way :). And about the program being too old to
handle it - 3.6.1 too old? POV 4 came faster than I thought ;)
Florian
Date: 22 Oct 2004 14:05:02
Message: <clbhv6$6eu$1@chho.imagico.de>
> <POV>
> #macro F_Plane ()
>   fn_p
> #end
> </POV>
BTW the correct way to do what you seem to be trying to do is
demostrated in the IsoCSG library.  What you wrote can't work although
it should of course not crash but return with an error.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 22 Oct 2004 15:13:30
Message: <20041022201329.3183eb65@dh286.pem.cam.ac.uk>
> > handle it, the reports come out funny."
> to handle it - 3.6.1 too old? POV 4 came faster than I thought ;)
I think that was another joke. Do try to keep up :->
Daniel
A most peculiar man    With the windows closed      And Mrs Reardon says
He died last Saturday  So he'd never wake up  He has a brother somewhere
He turned on the gas   To his silent world   Who should be notified soon
And he went to sleep   And his tiny room    .oO( http://sad.istic.org/ )
