POV-Ray : Newsgroups : povray.general : -QR setting Server Time
1 Feb 2026 02:38:45 EST (-0500)
  -QR setting (Message 1 to 3 of 3)
Subject: -QR setting
Date: 24 Sep 2004 08:59:30
Message: <41541a32$1@news.povray.org>
I'm sorry if this has been discussed before, but I couldn't find much
when I searched with the web interface.
It used to be that radiosity could be turned on and off from the command
line with +QR/-QR, but not anymore. Is this really the way most people
would like to have it?
I find that it's convenient to have a radiosity block with all kinds of
setting in it, and then have a simple way to toggle rendering with or
without radiosity (especially since I have a program which generates POV
files). IMHO, the best alternative would be to be able to disable
radiosity with -QR, but to have it on by default, if there is a
radiosity block in the scene file.
But maybe this behaviour is not likely to be changed again.
/ martin
Subject: Re: -QR setting
Date: 24 Sep 2004 13:05:29
Message: <415453d9@news.povray.org>
A way to achieve this without the (dropped) command lines parameters:
#declare USE_RADIOSITY = on;
global_settings {
	#if (USE_RADIOSITY)
		radiosity {
			//your settings here
HTH,
Florian
Minimum Requirement #6: You have setup three quake servers in your
company without the sysadmin noticing
(WEB.DE help-wanted ad: Linux Guru)
[------------ http://www.torfbold.com - POV-Ray gallery ------------]
Date: 28 Sep 2004 16:25:00
Message: <web.4159c85160b1a417a3fcf12a0@news.povray.org>
> / martin
You can use +q8. According to the documentation, quality level 9 turns on
media and radiosity. If you don't care about media, then +q8 is pretty much
the same thing as -qr.
