POV-Ray : Newsgroups : povray.general : Cylindrical HF Server Time
11 May 2026 21:02:20 EDT (-0400)
  Cylindrical HF (Message 1 to 7 of 7)
Subject: Cylindrical HF
Date: 12 Aug 2004 23:56:54
Message: <411c3c06$1@news.povray.org>
I need a cylindrical heightfield from my bitmap.
The following code doesn't work:
#include "shapes.inc"
#declare F = function {
       image_map {
       	png "foo.png"
         map_type 0
object {
    HF_Cylinder (F, off, off,
<60,60>, on, "", <0.5, 0.0, 0.5>, <0.5, 1.0, 0.5>, 0.4, 0.3)
       pigment {color rgb 1}
How can I make it work? Is there any other macro(s)
making cylindrical heightfield or cylindrical mesh
from bitmap?
Gena.
Subject: Re: Cylindrical HF
Date: 13 Aug 2004 00:56:41
Message: <411c4a09$1@news.povray.org>
"Gena" <gen### [at] yahoocom> wrote in message
news:411c3c06$1@news.povray.org...
>     pigment {
>        image_map {
>        png "foo.png"
>          map_type 0
> object {
>     texture {
It would seem that the macro needs the addition of  .gray  to H variable, as
in:
         #declare PArr[J][K] = P + H.gray*Dir*Depth;
or added to each of the two instances of it before that line.
I'm not sure why this would be nonfunctional for image maps in usual usage,
since I had thought those macros already considered for images. Maybe
someone else can speak as to what is going on about that.
Bob H.
Date: 13 Aug 2004 12:02:15
Message: <411ce607@news.povray.org>
There is a cylindrical HF macro distributed along with POV-Ray (at least
there used to be). Have you looked through the include library?
Hugo
Date: 13 Aug 2004 14:03:20
Message: <411D01C5.10401@hotmail.com>
>    pigment {
>       image_map {
>           png "foo.png"
>         map_type 0
> object {
>    texture {
> from bitmap?
> Gena.
I was just listing a bunch of things I thought _might_ be the problem,
but I'm 99% sure what the problem is now. Where you have "HF_Cylinder (F
", try making it "HF_Cylinder ( function{ F(x,y,z).grey } "
This macro demands you put the function inside a function{... } block.
Since you have declared a pigment as a function, you have to add the
".grey" to the end of the invoked function. I think that might be what
Bob was saying....
Here's what it will actually look like, in case the above was confusing:
HF_Cylinder (
  function{ F(x,y,z).grey } , off, off,
Hope this helps!
-Sam
Date: 13 Aug 2004 17:45:41
Message: <411d3685$1@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:411### [at] hotmailcom...
> Bob was saying....
> HF_Cylinder (
Not really... :-) A much better answer, Samuel! I made the mistake of trying
F(x,y,z).gray without the function {} wrapper and then went about changing
the macro itself. Bad idea. So real glad you saved the day by replying with
this solution. I should have known to do this!
Bob H.
Date: 14 Aug 2004 00:01:34
Message: <411d8e9e@news.povray.org>
Thank you! It works now.
Gena.
>>    pigment {
>>       image_map {
>>           png "foo.png"
>>         map_type 0
>> object {
>>    texture {
>> from bitmap?
>> Gena.
> Bob was saying....
> HF_Cylinder (
> Hope this helps!
> -Sam
Date: 14 Aug 2004 00:03:16
Message: <411d8f04$1@news.povray.org>
Yes, it's in shapes.inc
My code works now (thanks to Samuel).
Gena.
> Regards,
> Hugo
