POV-Ray : Newsgroups : povray.general : Placing png as semi-transparent image in front of pov object Server Time
1 Feb 2026 05:59:53 EST (-0500)
  Placing png as semi-transparent image in front of pov object (Message 1 to 4 of 4)
Subject: Placing png as semi-transparent image in front of pov object
Date: 31 Jul 2004 17:39:26
Message: <410c118e$1@news.povray.org>
I"ve forgotten how to do this.   I actually have images where I have an
image mostly transparent in front of my object. But it's not working now.
    box{<0,0,-0.0001>,<1,1,-0.0002>
      texture{
                pigment{ image_map {jpeg "w_myimage_gr.jpg"
                                filter all 0.9999
                                map_type 0 once }
               finish{diffuse 0 ambient 1}
        scale 45*<320/400,1,1>
          no_shadow
        translate -39*z-23*x+54*y}
Subject: Re: Placing png as semi-transparent image in front of pov object
Date: 31 Jul 2004 19:03:22
Message: <410c253a@news.povray.org>
Screen.inc may be the easiest solution.
In any case, we'd probably have to see your camera declaration to figure out
what's wrong (unless the problem isn't the position of the image, but the
appearance).
 - Slime
 [ http://www.slimeland.com/ ]
Date: 31 Jul 2004 21:56:02
Message: <410c4db2$1@news.povray.org>
Okay thanks. but what worked was making a GIF and then:
       texture{
                pigment{ image_map {gif "w_mygif_gri.gif"
                                //filter all 0.9999
                                transmit all 0.9900625
                                map_type 0 once }
          no_shadow
        translate -39*z-23*x+51*y}
Date: 1 Aug 2004 05:27:47
Message: <410cb793$1@news.povray.org>
"Greg M. Johnson" <gregj;-)565### [at] aolcom> schreef in bericht
news:410c118e$1@news.povray.org...
>       texture{
>                                 filter all 0.9999
>                                 map_type 0 once }
>           no_shadow
Your image seems to be jpg. Will not work AFAIF. With png (or tga) you can
define a transparant alpha channel.
