POV-Ray : Newsgroups : povray.general : Maths Question Server Time
22 May 2026 06:54:58 EDT (-0400)
  Maths Question (Message 1 to 3 of 3)
Subject: Maths Question
Date: 30 Jun 2004 12:23:29
Message: <40e2e901$1@news.povray.org>
I'm not a  maths guy, can any of you Gurus help me out here.
I've sussed detecting if two spheres intersect ( distance between centers
less combined radius ) but...
I want to detect if there is any collision between a box and a sphere with a
mathematical formular.  Can it be done?  How?
sphere is at    x1,y1,z1   and of radius n1.   Box is from    x2,y2,z2  to
x3,y3,z3
Thanks in advance...
Subject: Re: Maths Question
Date: 30 Jun 2004 13:15:47
Message: <20040630181547.7ab21ce3@dh286.pem.cam.ac.uk>
> with a mathematical formular.  Can it be done?  How?
>  to
> x3,y3,z3
A box is the intersection of three pairs of axis-aligned planes (where
a plane has an inside an an outside, like in PoV).
Collide the sphere with each plane in turn (this is easy) and apply each
of the following rules in the order given, where "partially inside"
means, for the plane at x3 (assuming x3>x2) x1-n1<x3; "entirely inside"
means x1+n1<x3; "entirely outside" means x1-n1>x3:
If the sphere is entirely outside any plane, they don't collide.
If the sphere is entirely inside all planes, they don't collide (the
sphere is inside the box).
If (x2,y2,z2) is inside the sphere and (x3,y3,z3) is inside the sphere,
they don't collide (the box is inside the sphere).
If the sphere is partially inside two opposite planes, they collide.
You still might get this circumstance, though:
     -.   sphere
       \  (almost)
       |  -_
  box  |    ---
where the sphere is partially inside exactly two non-opposite planes
(let's assume its the x-most and y-most planes, and that the point
marked with a + is (x3,y3,z3)). If, in this case, (x3,y3,z1) is inside
the sphere, they collide; if it is outside the sphere, they don't. Adapt
the choice of numbers and which co-ordinate is taken from the sphere to
suit which planes they are.
There is also the possibility for the above case to happen in 3D, where
the sphere is partially inside three planes that meet at a corner - if
this corner is inside the sphere, they collide; if it is outside, they
don't.
Phew.
Turning this into an actual algorithm is left as an exercise for the
reader. :-> You might like to look at the Cohen-Sutherland line-clipping
algorithm, which intersects points with boxes in 2D or 3D and uses
bitmasks and fast comparisons to do similar rules - it could easily be
adapted for this.
I hope this maths-dump is of some use to you.
Daniel
Misinformation followed us like a plague      You can beat us with wires
Nobody knew from time to time                You can beat us with chains
If the plans had changed         You can run out your rules but you know
   .: www.doublezero.uklinux.net :.   You can't outrun the history train
Date: 1 Jul 2004 04:45:56
Message: <40e3cf44$1@news.povray.org>
Thats great, thankyou for the time you put into answering.  I'll be printing
this off and fine-tooth-combing overnight.
