POV-Ray : Newsgroups : povray.general : One-way transmission? Server Time
18 Aug 2025 08:19:39 EDT (-0400)
  One-way transmission? (Message 1 to 2 of 2)
Subject: One-way transmission?
Date: 29 Jun 2004 13:01:38
Message: <40e1a072$1@news.povray.org>
I'd like to use an image as a "virtual" Duratran to dress out the
interior of rooms that are only viewed through a window or door. I
really don't want to render a bunch of furniture, etc. A static backdrop
is more than sufficient for this project.
What I'd like to do, is have the image mapped on a plane or box, with
the front surface (camera facing) normally opaque and reflective. Behind
the object, I'd like to use a soft light to illuminate the object from
behind.
This would allow me to keep a minimum of illumination/visibility even
when the room passes into shadow or for "night" scenes.
Anyone have any thoughts on the best way to implement this? Or even if
it's possible?
-David
Subject: Re: One-way transmission?
Date: 29 Jun 2004 18:00:47
Message: <40e1e68f$1@news.povray.org>
"David Nedrow" <lis### [at] nedronnet> wrote in message
news:40e1a072$1@news.povray.org...
> behind.
It could be that all you need is 'ambient' in the finish statement of the
image mapped object; using a value above zero, and perhaps below one so that
it still is affected by any light source(s) external to the room. With
diffuse being adjusted also, for how you want it to appear in light.
If the idea is to illuminate other objects, not only the image, then you
will need to use either the 'radiosity' or 'light_group' features. Light
groups have a lot of control over what gets lit and what doesn't. Radiosity
would be less controllable, and depend on diffuseness of the image maps
brighter parts.
That of any help?
I'm guessing you were not asking about invisible, yet interactive, objects.
That would require a 'no_image' in the object (camera doesn't see it even
though it reflects in other objects).
Bob H.
http://www.3digitaleyes.com
