POV-Ray : Newsgroups : povray.general : superimposing text Server Time
15 Jan 2026 15:39:09 EST (-0500)
  superimposing text (Message 1 to 7 of 7)
Subject: superimposing text
Date: 28 Jun 2004 13:23:00
Message: <40e053f4$1@news.povray.org>
I am running a lot of tests and I want to superimpose onto the viewing
plane a label naming which test the rendered image is the result of.
I am poking around in the resources etc. looking for something I could
use.  Would be very grateful for any code, suggestions, macros, includes
that I could press into service. I was sure someone had a technique for
applying his/her signature in that manner.
TIA
-Jim
Subject: Re: superimposing text
Date: 28 Jun 2004 13:35:18
Message: <kurtzlepirate-8AF326.19351828062004@news.povray.org>
In article <40e053f4$1@news.povray.org>, Jim Charter <jrc### [at] msncom> wrote:
> TIA
> -Jim
  make a look at "screen.inc"  :-))
  louis
Date: 28 Jun 2004 17:13:18
Message: <40e089ee$1@news.povray.org>
>   louis
Bingo.  Thanks Louis.
Date: 28 Jun 2004 17:39:34
Message: <40e09016$1@news.povray.org>
You're scenes are perhaps too complex for this method. Text objects are
slow anyway and will be terrible with high-quality radiosity and/or
multiple lights. What I do is call scenes from a small "wrapper" and
setup my ini file as a two-frame animation. The first frame is my scene,
the second frame labels it. This also makes it easier to keep multiple
pictures. Here's an example. I made it so you could cut-paste-run it to
check it out, but in reality, it would require that your main scene file
create a text file with all of the information you want to print.
Uncomment the commented lines and delete the lines labeled "fake line"
to get the real thing.
  -Shay
// for example, file saved as "text_label.pov"
#include "strings.inc"
#if ( 0 ) // fake line
//#if ( frame_number = 0 )
	#include "my_scene.pov"
#else
//	#include "my_data.pov"
		orthographic
		location <0,0,-1>
		look_at  <0,0,0>
		right 1*x
		up 1*y
	box {
		<-0.5, -0.5, 1>, <0.5, 0.5, 1>
//				image_map { sys "text_label1.bmp" }
				wood // fake line
			finish { ambient 1 }
			translate -.5
#macro Write ( String )
	#ifndef ( LineNumber )
		#declare LineNumber = 0;
	#else
		#declare LineNumber = LineNumber + 1;
	text {
		ttf
		"crystal.ttf",
		String,
		1,
		0
		scale .02
		pigment { rgb <1,1,1> }
	 	translate <-.49,.48,0>
		translate y*-.025*LineNumber
// in practice, variables like PTS and PTE
// would be defined in your data file
#local PTS = .008;
#local PTE = .04;
#local PtsString = concat ( "pretrace_start = ", Str(PTS) )
#local PteString = concat ( "pretrace_end = ", Str(PTE) )
Write ( PtsString )
Write ( PteString )
Date: 28 Jun 2004 21:05:07
Message: <40e0c043$1@news.povray.org>
Thanks Shay, will try it out.  There may be other reasons why I might
shift to running from an ini file too.
Date: 29 Jun 2004 10:13:59
Message: <40e17927$1@news.povray.org>
Multi pass renders? Stored radiosity?
  -Shay
Date: 29 Jun 2004 14:35:59
Message: <40e1b68f$1@news.povray.org>
>  -Shay
Obviously you can read minds
