POV-Ray : Newsgroups : povray.general : best import format Server Time
30 Mar 2026 14:19:06 EDT (-0400)
  best import format (Message 1 to 6 of 6)
Subject: best import format
Date: 31 May 2004 10:24:40
Message: <40bb4028$1@news.povray.org>
Hello. I am looking at a modeler that can export data in the following
formats:
.shade .dxf .obj .rib .lwo .3ds and .wrl
All things being equal, which would be the best to use for importing to POV?
Thanks much,
Dennis
dhm### [at] comcastnet
http://www.dennismiller.neu.edu
Subject: Re: best import format
Date: 1 Jun 2004 04:43:34
Message: <40bc41b6@news.povray.org>
I tend to use .obj and convert with 3DWin which can deal with batch
conversions - I take it this is a follow on from the XFrog group
disscussions? 3ds also works well - try both and choose the one best for
you.
If you are converting from XFrog to Pov be aware that Xfrog uses Tiff  image
maps with an alpha channel which will also need converting to jpg. Contact
me directly if you need help on this - the good news is that you only need
to do the conversion once for each plant.
example:
#declare PigPatLeaf = pigment{image_map{jpeg"GC12lefTR.jpg"}}  // B/W
transparency channel
#declare OpaquePigLeaf = pigment{image_map{jpeg"GC12lef.jpg"}}// Coloured
image map
#declare TransPig = texture{pigment{Clear}}
#declare T_Default_Leaf_TL = texture{
pigment_pattern{PigPatLeaf}
texture_map{
  [0 TransPig]
  [1 OpaquePigLeaf
  finish{ambient 0 diffuse 1 specular .1 }
All the best
Mick
Date: 1 Jun 2004 10:44:56
Message: <40bc9668$1@news.povray.org>
> formats:
Both Wings3D and Blender support most of them, if not all, either built-in
or by plugins. I recommend both.
POV?
Both Wings3D and Blender have plugins for direct exporting to POV.
Roberto
Date: 1 Jun 2004 13:10:28
Message: <40bcb884$1@news.povray.org>
news:40bb4028$1@news.povray.org...
OBJ is a good format :
- it is supported in import by most software (except native Rhino?).
UVMapper only works with OBJ.
- it's a text format so it's possible to open an obj file and look for
problems if necessary.
- obj file are often quite similar in size to mesh2 files. This is useful to
get an early idea (before conversion) of a mesh2 size. It's frequent that I
export an obj, look at the size and then go back to the original app (Rhino,
Xfrog, C4D...) to reduce the number of polys until I get something
acceptable.
- I've run in relatively few problems with OBJ, unlike DXF or LWO (due to
the different flavours available for these formats). The problems I had with
OBJ were caused by faulty exporters, but these problems also exist for other
formats.
3DS is also a good format to consider: it's well supported and binary files
are smaller, but it has a limitation in the number of polys (32000 I think)
for a single object, so large objects sometimes end up being cut up in
smaller pieces or disappear after conversions.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
- Posters
Date: 3 Jun 2004 10:25:14
Message: <40bf34ca$1@news.povray.org>
Great stuff - thanks for the input. Sounds like OBJ might be the best option
in this case. I'll do some comparisons and see what happens.
Thanks again,
Dennis
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:40bcb884$1@news.povray.org...
to
I
(Rhino,
> acceptable.
with
other
> formats.
files
think)
> G.
> - POV-Ray and Poser computer images
> - Posters
> - Posters
Date: 3 Jun 2004 14:30:24
Message: <40bf6e40@news.povray.org>
I'm sorry, I misunderstood your question. I use .OBJ myself, I've found it
to be the most "compatible" and dependable one.
Roberto
