POV-Ray : Newsgroups : povray.general : Translating turbulence Server Time
12 Jun 2026 01:32:45 EDT (-0400)
  Translating turbulence (Message 1 to 4 of 4)
Subject: Translating turbulence
Date: 18 May 2004 14:17:39
Message: <40aa5343@news.povray.org>
Let's say you've got a sphere filled with media and a spherical density.
You add a turbulence warp and you get the same pattern each time.  You could
rotate or scale the density to make look a little different at different
angles, but the pattern of the turbulence remains the same.  Is there a way
to translate a turbulence warp so that it's sampling from a different part
of the pattern?
Skip Talbot
Subject: Re: Translating turbulence
Date: 18 May 2004 14:40:28
Message: <Xns94EDD24F1E61Cseed7@news.povray.org>
in news:40aa5343@news.povray.org Skip Talbot wrote:
> Is there a way
> part of the pattern?
Translate the spherical pattern to somewhere random, apply turbulence,
translate the whole thing to the position you want.
Changing the seed for turbulence would be nice option.
      spherical
      translate <3,3,3>
      warp {
        turbulence 0.3
      translate <-3,-3,-3>
      color_map {
        [0.0 color rgb 0.0 ]
        [1.0 color rgb 1.0 ]
Ingo
Date: 18 May 2004 19:30:33
Message: <40aa9c99$1@news.povray.org>
Ah ha, excellent idea, I thought there was a solution along these lines but
I couldn't quite piece it together.  Thanks again.
Skip Talbot
Date: 19 May 2004 17:32:35
Message: <cjameshuff-8046AD.16325219052004@news.povray.org>
In article <Xns94EDD24F1E61Cseed7@news.povray.org>,
 ingo <ing### [at] tagpovrayorg> wrote:
>       translate <3,3,3>
>       warp {
>         turbulence 0.3
You should also remember that the "warp {}" is necessary...otherwise,
turbulence will be done first, no matter what its order relative to the
other transformations is. As I recall, this dates from a time when
turbulence was a separate feature, before warps were added.
You can package it into a nice little macro:
#macro Turbulence(Amt, Trans)
    transform {Trans inverse}
    warp {
        turbulence Amt
    transform {Trans}
#macro TurbulenceOLO(Amt, Octaves, Lambda, Omega, Trans)
    warp {
        turbulence Amt
        lambda Lambda
        octaves Octaves
        omega Omega
    transform {Trans}
TransformedTurbulence(0.3, transform {translate <-3,-3,-3>})
http://tag.povray.org/
