POV-Ray : Newsgroups : povray.general : Some general questions about LONG traces - newbie Server Time
19 Apr 2026 17:39:45 EDT (-0400)
  Some general questions about LONG traces - newbie (Message 1 to 10 of 10)
Subject: Some general questions about LONG traces - newbie
Date: 15 May 2004 04:04:29
Message: <40a5cf0b@news.povray.org>
Hi guys
I am fairly new to PovRay and I have ran into some issues - wonder if you
can help?
1. What is a common trace time for complex images (lots of reflection /
refraction, many objects)
I realise this is subjective, but I have reasonably simple scenes (10 000
objects, and about 30 reflective/refractive objects, ten light sources)
that take literally weeks to render while various IRTC entries I have seen,
with scenes literally thousands of times more complex (as regards APPARENT
objects and reflections / refractions) done with PovRay, render in times of
2 or 4 hours. So IS two weeks tracetime (or even a month) for a 1152x864
image acceptable, or am I doing something exceedingly stupid? Or is this so
subjective its not worth an answer? I am referring to times on a
"standard"-ish system - P4 2.0 GHz with 512MB on Rh9 Linux, the raytrace
being the only user process running.
Is there anybody else out there with such long tracetimes? How did you
reduce them without losing scene quality?
2. How exactly to use adc_bailout?
To decrease render time in scenes with lots of reflections / refraction, it
seems to me that I should use larger adc_bailout values (0.05+ ?) and lower
max_trace_level values (5 or less?) The default values are taking simply
too long - and apparently there is no difference for me yet, as a test
scene is taking forty hours to get to a certain point, with or without
adc_bailout set to 0.05 and max_trace_level set to 5, while having the
reflective and refractive objects in that particular part of the image.
3. Aborting?
If I abort a trace in the middle of a horizontal line, do the pixels
calculated up to that point get saved to disk? I. e. if tracing one line of
1152 pixels takes two hours, and I abort an hour into the line, do I loose
all the pixels finished up to that point, or does PovRay resume from there?
Or does it start over a x=0 on that line? What if I force PovRay to exit
instead of CTRL-C (in Linux) and waiting for it to exit in its own time?
Can I force PovRay to write each, say, 25 pixels to disk? How does the
abort_count option influence this? Does it control how regularly pixels are
saved to file?
4. Pointers / hints?
Any URL's or info on PovRay optimisation? I have often looked for
optimisation guides for programming, but are there any for the PovRay scene
language?
5. Reasons for scanline renderers being faster - is scanline better?
I have seen images created with 3DStudio that would (I think) take YEARS to
render with PovRay. Which technique is better, i. e. which program is
better - a scanline renderer (what does that mean? What is the difference
between that and raytracing?) or a raytracer? I have heard about IPAS
modules for 3DStudio that do raytracing - so 3DS can do both? Why is
scanline so very much faster than raytracing, but looks just as good?
Anyway, thanks for your time!
Stefan Viljoen
Software Support Technician
Polar Design Solutions
Subject: Re: Some general questions about LONG traces - newbie
Date: 15 May 2004 05:05:55
Message: <40a5dd73$1@news.povray.org>
Quiet an extensive set of questions you've got there...
This truly depends on the scene, how much the objects interreflect each
other etc.
I never fiddle with that one unless using Focal blur.
> 3. Aborting?
AFAIK, POV-Ray automatically saves to disk, but in bunches. I believe that
can't be properly controlled (in terms of every 25 pixels or such), but
rather in Bytes. But someone should correct me on this.
I've got none.
Scanline has some advantages that a raytracer doesn't have. For one, it
makes use of the GPU's it may find on a Graphic card. Most of the
calculations don't require heavy floating point calculations, which is
pretty slow on some processors and, AFAIK, not a part of the CPU which is
needed that often, hence it isn't as accessible and quick like other
operations. The main performance part lie in those two points: making use of
the graphics hardware and the slow performance when comparing that to the
floating point calculations. Just look at typical PC Games, they're scanline
all over the place, and they've sometimes got tons of triangles to display.
But then again, scanline simulates a lot and doesn't always have the precise
calculations raytracing offers.
Tim
"Tim Nikias v2.0"
Date: 15 May 2004 08:02:07
Message: <40a606bf@news.povray.org>
  If I'm not completely mistaken, adc_bailout does not work in POV-Ray 3.5
due to a bug, but AFAIK this has been fixed in POV-Ray 3.6.
http://tag.povray.org/povQandT/miscQandT.html#renderingspeed
  Basically scanline rendering makes tons of shortcuts to produce images
which look similar to raytraced images, but which really aren't. There
are many things which are practically impossible to do with a scanline
renderer and which are trivial with a raytracer (for example two
reflecting objects reflecting each other again and again and again).
  If a raytracer used the same tricks as most scanline renderers to
achieve certain effects (such as shadows by using lightmaps instead of
tracing, reflections using reflection maps instead of tracing, using
only triangles to build the scene, etc etc) it would speed it up
considerably. However, raytracers are usually not intended for that:
When you want a raytracer you want it because you want precise shadows,
precise reflections, precise refractions, precise mathematical surfaces etc.
  Another reason is that most effects are very easy to implement with
a raytracer but very laborious to implement in a scanline renderer.
For example the reflection calculations in a raytracer (once you have
the basic tracing function done) can perfectly be done in less than 10
lines of simple code. In a scanline renderer good-looking reflections
require thousands of lines of complicated code (in addition to the
basic triangle projection code).
Date: 15 May 2004 09:37:35
Message: <40a61d1f$1@news.povray.org>
Stefan Viljoen <rylan@ nous apporta ses lumieres ainsi en ce 2004/05/15
04:00... :
>Hi guys
>can help?
Each light increase significantly the render time. Sometimes, you can
reduce the number of light by using a shadowless light or by changing
the ambient value. If a light only affect a small part of your scene,
make it a spot light. Features like focal_blur, photons and radiosity
increase render time. Turn off the first two for the test renders. For
small, distent or partly occulted object, use lower settings, simpler
textures, normal instead of iso_surface.
><snip>
>language?
Using isosurfaces? Try using tighter bounding shapes. Fine tune
max_gradient to make it as small as possible. Having a cylindrical or
spherical iso? Try to replace it with a similarly looking lathe or sor.
If you have intersection or difference of very large or infinite
primitives, use manual bounding.
Scanline use shortcuts, hardware acceleration, use
prerendered/precalculated elements, use fake reflections, usualy don't
bother with refraction (I saw one (1) exeption). Fast and dirty.
>Regards,
Date: 15 May 2004 11:40:45
Message: <cjameshuff-FBFC1F.10405615052004@news.povray.org>
In article <40a5cf0b@news.povray.org>,
Minutes to hours, for me.
You're probably doing something stupid. ;-)
There are things that will take that long, but usually just odd
experiments. Typical scenes don't take weeks to render.
I generally set max_trace_level to at least 12. Higher values of
adc_bailout will make POV stop tracing sooner. My guess is that you're
doing something else that's causing the high render times.
> language?
None that I know of which are specifically for optimizing. The manual
has some general pointers for specific features like radiosity and
photons.
It is for realtime display of the type used by today's games, and for
other applications where speed is of great importance.
Raytracers simulate the actual paths light takes through the scene. It
follows the light that in the real world would enter the camera back
into the scene, and then figures the illumination from light sources and
the environment which contributes to that light. It handles refraction,
reflection, and diffuse illumination with trivial additions, and can
easily be extended to include things like photon maps.
Scanline renderers, on the other hand, use a process more like painting
or drawing. They consider the scene as a bunch of polygons, and project
each polygon onto the screen, filling each polygon scanline by scanline
and compositing it onto the existing image. They really can't do
reflection or refraction, they have to fake it with things like
environment maps...a view of the surrounding scene is rendered from a
point inside the refracting/reflecting object, and that view is mapped
on the surface of the object, using the normals and camera position to
make it look something like reflection or refraction. You could do the
environment map for every vertex or every pixel instead, but this would
basically be doing raytracing with a scanline engine, and would probably
be even slower than an actual raytracer. Scanline renderers usually use
raytracing for accurate reflections, shadows, and transparent objects.
> render with PovRay.
Unlikely. Raytracing actually performs better than scanlining with
extreme amounts of detail.
Raytracers are more accurate. Scanline renderers are generally faster
for typical scenes being done today.
3DS can mix raytracing into its scanline renderings. I don't know if it
does full raytracing...doing so would not be difficult, though. And
scanline renders typically *don't* look just as good
Date: 15 May 2004 11:54:00
Message: <Xns94EAB61692379seed7@news.povray.org>
> scene language?
Stefan,
POV-Ray has two tools to help you see what is going on in your scene.
- The statistics output after rendering, espescialy the ray-shape
intersections part.
- The histogram, it gives you a good indication what sections of your
image take the most time.
Now knowing the existence of these is one thing, using them in a usefull
way is another. It would be nice if somebody wrote a tutorial on using
these and possible other methods for optimising the rendering. The
advanced section of the docs could use something in that direction.
Ingo
Date: 15 May 2004 12:15:15
Message: <40a64213@news.povray.org>
04:00... :
<snip>
Could you post your problem scene(s) in povray.binaries.scene-files so
peoples can have a look and maybe spot just what is causing your renders
to take so long.
Date: 15 May 2004 14:34:33
Message: <40a662b9@news.povray.org>
As Warp said, adc_bailout is buggy in POV-Ray 3.5. Don't bother with it
unless you're using the 3.6 beta.
As for your slow scene, I recommend you show us the scene file. Tricks to
speed it up will likely be specific to the scene and how you're doing things
within it.
10 light sources is a lot though; see if you can cut that down. Turning some
of them into spotlights, or using light_groups may help also.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 15 May 2004 16:12:39
Message: <40a679af@news.povray.org>
Thanks guys!
I'll try fewer lights and tighter bounding... darn! Glad I found POV and
that there are such nice ppl in the community, willing to help a newbie.
Happy (and QUICK :) tracing.
Stefan Viljoen
Date: 15 May 2004 16:13:12
Message: <cjameshuff-6BA3F5.15132415052004@news.povray.org>
In article <40a662b9@news.povray.org>, "Slime" <fak### [at] emailaddress>
As I recall, it's buggy in radiosity, but the setting used for reflected
and refracted rays does work.
