POV-Ray : Newsgroups : povray.general : Please Help Me Find My Stupid Mistake Server Time
26 Dec 2025 22:10:50 EST (-0500)
  Please Help Me Find My Stupid Mistake (Message 1 to 4 of 4)
Subject: Please Help Me Find My Stupid Mistake
Date: 6 May 2004 14:19:05
Message: <409a8199@news.povray.org>
The code below works, but by my reasoning it shouldn't.  I had to move a
"}" to what is "clearly" the "wrong" location (obviously it isn't wrong,
since it works; what is wrong is my logic.)  When I close out my objects
the way I think I should, I get a parse error.  Can someone spot my
mistake?
(If the code seems a bit strange, it's because I've stripped it down as
  much as I can, I think, and still have the problem.)
////////Code
//Ball-And-Stick Fragment
#macro B_And_S_Triangle(V_Array,BR,SR)
         union {
         sphere { 0, 1  scale BR pigment { color rgb x }
                  translate V_Array[0]}
         sphere { 0, 1  scale BR pigment { color rgb y }
                  translate V_Array[1]}
         sphere { 0, 1  scale BR pigment { color rgb z }
                  translate V_Array[2]}
         cylinder { V_Array[0], V_Array[1], SR
                    pigment { color rgb x+y } }
         cylinder { V_Array[0], V_Array[2], SR
         cylinder { V_Array[1], V_Array[2], SR
//Of Macro The problem's probably somewhere above, but I can't find it.
// Second macro, calls above macro twice:
#macro Ball_And_Stick(SArray,DArray,B_Rad,S_Rad)
#declare Source_Triangle =
                      B_And_S_Triangle(SArray,B_Rad,S_Rad)
#declare Destination_Triangle =
                      B_And_S_Triangle(DArray,B_Rad/2,S_Rad/2)
//Here's "misplaced" "}"
object { Source_Triangle }}
//I think there should only be one "}" ending above object
object { Destination_Triangle }
#end    //Of 2nd macro
// Here's the main body
#declare Source_Points = array[3];
#declare Source_Points[0] = <0, 0, 0>;
#declare Source_Points[1] = <0, 5, 0>;
#declare Source_Points[2] = <5, 0, 0>;
#declare Destination_Points = array[3];
#declare Destination_Points[0] = <1, 1, 0>;
#declare Destination_Points[1] = <2, 1, 0>;
#declare Destination_Points[2] = <1, 2, 0>;
//Here's "missing" "}"
object { Ball_And_Stick(Source_Points,Destination_Points,0.5, 0.1)
//I think there should be a "}" to end the above object.
camera { angle 60 location <3, 3, -20>
	look_at <3, 3, 0>
         up y }
light_source { -100*z color rgb 1 }
background { color rgb 0.7 }
I've been tearing out what little hair I have left, trying to solve
this.  Thanks in advance for any help.
Dave Matthews
Subject: Re: Please Help Me Find My Stupid Mistake
Date: 6 May 2004 14:58:23
Message: <409a8acf$1@news.povray.org>
Never mind.  I found it.  I need a "union" in my second macro to make it
work the way I thought it should -- i.e. treat it as a single object.
Dave Matthews
> mistake?
> ////////Code
>         union {
> #end
> #end    //Of 2nd macro
>     look_at <3, 3, 0>
>         up y }
> Dave Matthews
Date: 6 May 2004 15:25:40
Message: <$P1zNDAyDpmAFw8J@econym.demon.co.uk>
>mistake?
The problem is that the Ball_And_Stick() macro doesn't return an object,
it returns two objects. So you can't say
  object { Ball_And_Stick(Source_Points,Destination_Points,0.5, 0.1) }
You can fix it by saying
  union { Ball_And_Stick(Source_Points,Destination_Points,0.5, 0.1) }
or by making Ball_And_Stick() return a single union of the two objects
  union {
The error message isn't very helpful, but I guess that the POV parser
got just as confused as you did.
Mike Williams
Gentleman of Leisure
Date: 7 May 2004 11:11:04
Message: <409ba708$1@news.povray.org>
>   union {
Thanks, Mike.
As you can see, above, I finally found it also.  Actually what made it
dawn on me, was trying to translate the whole thing.  Only the first
part moved, then I realized that I had two objects.
Dave Matthews
