POV-Ray : Newsgroups : povray.general : parametrics in density Server Time
2 Mar 2026 05:29:05 EST (-0500)
  parametrics in density (Message 1 to 2 of 2)
Subject: parametrics in density
Date: 5 May 2004 02:05:33
Message: <4098842d$1@news.povray.org>
Is there a way to use a parametric as a media density?  Trying to make a
curvey type funnel.
Skip Talbot
Subject: Re: parametrics in density
Date: 6 May 2004 16:47:33
Message: <cjameshuff-874EA5.15465006052004@news.povray.org>
In article <4098842d$1@news.povray.org>,
> curvey type funnel.
No. Think about what a density pattern *is*: it defines a density value
over 3D space. Parametric shapes take parameters within a certain range
and translate them into points on a surface. Implicit functions, such as
those used by the isosurface shape, define the surface as all points
where a function is equal to some value. The value of the function is
defined at (nearly) all points, and can easily be used directly as a
density value or to determine whether a point is inside an isosurface.
You could use parametric functions to generate a density file, and in
some cases you could convert the parametrics into implicit form, but as
a general rule, the idea of using parametrics as media densities just
doesn't make sense.
http://tag.povray.org/
