![](/i/fill.gif) |
I want to render only the exterior surface after merging two
semi-transparent objects. Although the original sruface of each object
inside the CSG is not traced, pov-ray traces a new surface that intersects
the two objects. Is there a way to hide this interface?
Tom
![](/i/fill.gif) |
![](/i/fill.gif) |
tomlee wrote:
> Hi,
If you use "merge" this should not be the case, all inner surfaces get
removed. Can you post a minimal scene example that shows your problem?
Maybe you just have to increase max_tracelevel?
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
![](/i/fill.gif) |
![](/i/fill.gif) |
It may help understanding what you mean if you post a short example
scene showing the effect you are talking about.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
