POV-Ray : Newsgroups : povray.general : Parse Error: Degenerate cylinder Server Time
23 Nov 2025 05:05:38 EST (-0500)
  Parse Error: Degenerate cylinder (Message 1 to 4 of 4)
Subject: Parse Error: Degenerate cylinder
Date: 28 Mar 2004 10:05:22
Message: <4066e9b2$1@news.povray.org>
I just wanted to ask if it is possible to change the parse time error
"Parse Error: Degenerate cylinder, base point = apex point."
into a simple warning. The same goes for a mesh without triangles. I
don't see why the render has to be stopped in such a case. IMHO it is
good to inform the user about it, but rendering could go on, couldn't it?
I ran into this in an object generating macro and of course I could
check the points before creating the cylinder, but that would really
increase parse time. And no, I don't want this changed because I'm too
lazy to check the points, but because I think the current behaviour is
unnecessarily strict (And it would be a really small change, too).
Spring is coming!
Florian
Subject: Re: Parse Error: Degenerate cylinder
Date: 30 Mar 2004 17:39:07
Message: <4069f70b$1@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:4066e9b2$1@news.povray.org...
It's especially odd because other non-viewable objects, such as cylinders
and spheres with radii of 0 or even negative numbers, don't even generate
warnings.  Perhaps its something with how the cylinder is processed
internally, that is, what is the function for a cylinder?  It might be
something that just chokes when the two points are the same.
...Chambers
http://www.geocities.com/bdchambers79
Date: 30 Mar 2004 20:07:05
Message: <pan.2004.03.31.01.09.13.230617@NOSPAMml1.net>
I think that's the case. My theory is this. A cylinder with both points
equal is a disc, or to put it another way, the intersection of a sphere
and a plane. However, pov-ray doesn't (can't) know what the plane would
be, thus it's ambiguous.
Date: 31 Mar 2004 06:33:36
Message: <406aac90@news.povray.org>
I'd just say skip
- meshes with no triangles
- spheres and cylinders with radii = 0
- cylinders with apex = base
- all the other non-viewable objects
simply generate a warning that the object has been ignored. In the case
of the cylinder (apex=base) being a disc actually, I think, as this disc
is not really defined (because it's normal can not be computed), it's as
senseless as a sphere with radius 0.
Florian
