POV-Ray : Newsgroups : povray.general : Odd behavior of 1/sqrt functions in iso_surface Server Time
23 Nov 2025 07:06:14 EST (-0500)
  Odd behavior of 1/sqrt functions in iso_surface (Message 1 to 7 of 7)
Subject: Odd behavior of 1/sqrt functions in iso_surface
Date: 9 Mar 2004 02:22:17
Message: <404d70a9@news.povray.org>
When I attempted to render the gravitation equipotential surface of two
bodies (i.e the surfaces of the double planet in Robert Forward's
"Flight of the Dragonfly"). The iso_surface object behaved oddly with
these three behaviors:
1) If the contained_by shape is larger than the true surface for the
given threshold value, the entire contained_by shape (either box or
sphere) is rendered as part of the surface.
2) If parts of the surface extend beyond the contained_by shape, you get
the difference of the contained_by shape and the true surface. (this is
shown in POVRay Example 1 below)
3) If the contained_by shape is made large enough to contain the true
surface, camera, and light_source, you get the correct results for the
iso_surface, but it takes a long time to render since every point in the
scene has to be tested.
Since the Gravitational potential is a function of 1/r the function used
is 1/sqrt(x*x+y*y+z*z)
To test where this behavior originates, I did 3 other test files (shown
in Examples 2, 3, and 4 below) which should have all produced the same
result, a sphere of radius 4.47214 (i.e. sqrt(20.0)), with the following
results
Example 2: the function was x*x+y*y+z*z, threshold 20.0
Result: Worked with the proper max_gradient
Example 3: the function was sqrt(x*x+y*y+z*z), threshold 4.47214
Example 4: the function was 1/(sqrt(x*x+y*y+z*z)+0.0001), threshold 0.22361
Result: Behavior like Example 1, regardless of max_gradient, in fact for
the case where the contained_by shape is larger than the expected
surface, random values of max_gradient make no difference and no value
is printed in the messages so the test of the function is apparently not
taking place.
I've tested this with both linux and Windows versions of POVRay 3.5 with
the same results so it appears to be something pathological in the code
when the function involves 1/sqrt.  Does anyone have any insight into this?
Richard Kline
//Begin Example 1
#include "shapes.inc"
#include "shapes2.inc"
#include "textures.inc"
         location <0.0, 120.0, -75.0>
         up < 0.0, 1.0, 0.0>
         right < 4/3, 0.0, 0.0>
         look_at <5,30.0,0>
         angle 60
light_source { <25.0, 200.0, -80.0> color White}
#declare Roche = function {
10.0/(sqrt(x*x+y*y+z*z)+0.000001) +
10.0/(sqrt((x+20)*(x+20)+y*y+z*z)+0.000001)}
plane { y,-20
pigment { hexagon pigment {Red}, pigment {Gray50}, pigment {Blue} scale 10}
isosurface {
         function { Roche(x,y,z) }
         contained_by { box {<-15,-5,-5>,<-5,5,5>} }
         threshold 2.0
         max_gradient  84
         texture {pigment {Green} finish {Dull}}
         scale <4.5,4.5,4.5>
         translate <30,25,0>
// Rotations to show the difference shape
         rotate <0,90,0>
         rotate <30,0,0>
//End Example 1
//Begin Example 2
         up < 0.0, 1.0, 0.0>
         look_at <5,30.0,0>
         angle 60
#declare Sphere1 = function {
         x*x + y*y + z*z }
plane { y,-20
isosurface {
         function {Sphere1(x,y,z)}
         contained_by { box {<-6,-6,-6>,<6,6,6>}}
         threshold 20.0
         max_gradient 16.0
         scale <4.5,4.5,4.5>
//End Example 2
//Begin Example 3
         up < 0.0, 1.0, 0.0>
         look_at <5,30.0,0>
         angle 60
#declare Sphere2 = function {
         sqrt(x*x + y*y + z*z) }
plane { y,-20
isosurface {
         function {Sphere2(x,y,z)}
         threshold 4.47214
         max_gradient 1.0
         scale <4.5,4.5,4.5>
//End Example 3
//Begin Example 4
         up < 0.0, 1.0, 0.0>
         look_at <5,30.0,0>
         angle 60
//The +0.0001 in the denominator of the function is to ensure no
// possibility of a divide by zero occurring
#declare Sphere3 = function {
         1.0/(sqrt(x*x + y*y + z*z)+0.0001) }
plane { y,-20
isosurface {
         function {Sphere3(x,y,z)}
         threshold 0.22361
         max_gradient 100.0
         scale <4.5,4.5,4.5>
//End Example 4
Subject: Re: Odd behavior of 1/sqrt functions in iso_surface
Date: 9 Mar 2004 02:55:41
Message: <J5vaSSAyhXTAFwx9@econym.demon.co.uk>
I confess to not having tried all your examples, but what you describe
sounds exactly like rendering the isosurface inside out.
See <http://www.econym.demon.co.uk/isotut/insideout.htm>
The "inside" of an isosurface is the region where the function minus the
threshold is less than zero and the outside is where it's greater than
zero. For some functions this may be different from what common sense
tells you should be the inside and outside.
Try using "isosurface {function {0 - Roche(x,y,z) }" and
"threshold -2.0" to flip the thing right side out.
Mike Williams
Gentleman of Leisure
Date: 9 Mar 2004 03:15:02
Message: <c2ju9u$21p$1@chho.imagico.de>
You should note that the above function has a singularity at <0,0,0>.
You should never expect such a function to render correctly if the
singularity is inside the container (the fact that POV-Ray reports a
finite maximum gradient does not mean anything here).
Last updated 07 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 9 Mar 2004 08:20:25
Message: <404dc499$1@news.povray.org>
By default isosurfaces are solid objects, AFAIK every point where the
function evaluates to something greater than zero is considered to be
inside.
If you only care about the surface itself, you may want to use the
'open' keyword. Or use the negative of the function to invert inside
and outside.
This is the function for a singularity. It might cause problems with the root
solver, since it doesn't really have a maximum gradient.
In this case you might want to use the function for a hollow sphere with a
radius of R instead.
Thats is  1/r for r > R
          1/R for r <= R
Lutz-Peter
Date: 9 Mar 2004 09:09:28
Message: <cjameshuff-D426FF.09092809032004@news.povray.org>
In article <404d70a9@news.povray.org>,
Others have already mentioned the singularity problems at <x, y, z> = 0.
In addition, gravitational fields have an inverse *square* falloff,
1/r^2.
http://tag.povray.org/
Date: 9 Mar 2004 11:38:39
Message: <404DF56C.2060900@informatik.uni-freiburg.de>
> 1/r^2.
The (gradient) field does, yes. But the potential is of type 1/r.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 9 Mar 2004 22:15:25
Message: <404e884d@news.povray.org>
Negating the function and threshold worked.  Thanks.  Also to the other
respondents, I did add 0.0001 to the denominator of the function to
avoid having a singularity.  I just didn't mention it up top.
Richard Kline
