POV-Ray : Newsgroups : povray.general : Skin texture and hair? Server Time
30 Mar 2026 23:13:42 EDT (-0400)
  Skin texture and hair? (Message 1 to 6 of 6)
Subject: Skin texture and hair?
Date: 3 Mar 2004 12:59:44
Message: <40461d10$1@news.povray.org>
I posted my newly completed human head mesh on p.b.i. I asked for
suggestions or recommendations for skin texture and hair, but none of the
replies have addressed that. So I'll try here. I'm looking for the most
realistic effect possible. Any suggestions will be appreciated.
Thanks,
Steve Shelby
Subject: Re: Skin texture and hair?
Date: 3 Mar 2004 14:34:22
Message: <4046333e@news.povray.org>
> Thanks,
> Steve Shelby
It's an ongoing hunt at this point.  Traditionally the grail of skin
texturing is to effect the slight glow created by its translucency.
THis has been true in centuries of painting long before cg came along.
Traditionally this was effected with variations on the layering of
translucent paint to suggest the underlaying textures of skin
pigmentation, veins and so on mixed with strategies of playing the
chromatic effects of colors off of one another to produce some of the
visual effects of flesh.   In the renderman world, shaders have been
experimented with that try to simulate subsurface scattering which is
another recognition of the layering of pigment effects in the skin.  The
best cg effects seem to come from the buildup of layers of texture in a
graphiccs editing program such as PhotoShop then applying this as a
image map.  That is why I alluded to uv support in Moray in my reply to
you.  There is of course the possibilility of applying image maps in
transparent layers though I'm not sure this gains anything over just
combining layers in PS
In POV there has been some experimenting with subsurface scattering
effects through filling the object with a dense media and keeping the
surface transparent.  But this precludes the ability too include the
textured pigmentation characteristic of skin ( you know freckles ,liver
spots etc. )  One sss experiment seemed to be about shooting a fine
layer of blobs from the lightsource at an object and making that somehow
translucent.  The experiment was done with a candle or figureen I think
but if I am understanding the technique correctly it might allow the
combination of layered pigmentation effects with translucent effect.  I
have tried filling the object with a media and using some sort of
semitranparent surface texture to little advantage.  Again the most
powerful illusions I've seen on the more commercial sights have combined
a highly chromatic texture of skin mottling with an very effective use
of bumpmapping, ignoring the sss issue altogether.  Other concerns,
outlined recently by Gilles Tran are the separation of different finish
effects, specular, reflection, diffuse.  This is done through the
application of separate maps in commercial apps.  It takes a bit of
sleight of hand with layering of textures in POV to get this to happen.
  In short, some component of the texture needs to be repeated in every
layer it seems.  I have been surveying how this is done in commercial
apps and trying to apply it to POV.  But I am far from being able to
discuss it confidently yet.  Applying texture maps is the approach that
is most likely to pay off.  So you are going to have to get good at
making uvmaps imo.
Hais is another grail.  Most use the POV pigment_pattern to draw hair
onto a transparent bit of mesh.  This mimicks the approach of commercial
software.  I have also been playing with the generation of individual
hair which may have some limited application.
A couple of links:
 From a recent G Tran post:
Regular POV 3.5, 3-point lighting :
http://www.oyonale.com/histoire/images/vicky3_test.jpg
MLPov, Kitchen probe HDRI lighting
:http://www.oyonale.com/histoire/images/vicky3_hdri_test.jpg
I tend to believe that POV-Ray code could make good skin textures but more
control is needed on the finish. What I think is missing is the possibility
to tweak specularity by having more control on the falloff curve and on the
illumination type. Also sorely missing in regular POV is an angle of
incidence pattern (it's in MLPov) which is extremely useful for more more
things than reflection (where it exists in 3.5). Below is the same Vicky,
this time in Cinema 4D with HDRI and specularity and aoi tweaks. It could be
better but it's getting there (and I'm a newbie so there's ample room for
progress).
http://www.oyonale.com/histoire/images/vicky3_hdri_c4d_test.jpg
Below are details of a series of images I did in POV-Ray 3.5 recently (the
images themselves are not on the site yet), where the characters' skin or
fur were rendered with a faked aoi texture using a slope map linked to the
camera:
http://www.oyonale.com/ldc/images/grandrue_est_bleu_detail1.jpg
http://www.oyonale.com/ldc/images/grandrue_est_detail1.jpg
Note that these images are less "genuine" than the previous tests, since
there was a lot of artifact removal post-render and some compositing.
Date: 3 Mar 2004 15:01:47
Message: <zNAUvBAGfjRAFwk$@econym.demon.co.uk>
I don't know about skin textures, but some of the most realistic hair is
made by Kozaburo and is available free from <http://DigitalBabes2.com>
It's designed to be used in Poser, but you can lift the OBJ file and the
texture maps from the zip file, convert the OBJ to a mesh and render in
POV by using a texture like
#declare HairTex = texture {
  pigment_pattern {image_map {jpeg "kyokohairmk3_tr.jpg" interpolate 2}}
  texture_map {
     [0 pigment {rgbt <0,0,0,1>}]
     [1 pigment {image_map {jpeg "kyokohairmk3_blondtx.jpg"
                interpolate 2}}]
The way it works is that rather than modelling every single hair (which
is tricky to do, takes AGES to render and doesn't tend to look very
realistic) the hair is modelled as a number of layers of transparency
mapped sheets. The individual hairs are drawn onto the transparency map
image.
I'll post an example in p.b.i of a POV rendering of his Kyoko Hair MK3,
in which I converted the kyokohairmk3.obj file directly to a POV mesh,
not using Poser at all, and applied the supplied transparency map and
texture map as shown above.
If you want to make your own realistic hair, I'd recommend grabbing
copies of some of Kozaburo's creations and taking them apart to see how
they work.
Mike Williams
Gentleman of Leisure
Date: 9 Mar 2004 08:17:54
Message: <404dc402$1@news.povray.org>
Thank you for your reply. I've been experimenting this past week with skin
texture in Moray, using UV mapping and layered texture. I'm posting an image
to p.b.i.
Steve Shelby
news:4046333e@news.povray.org...
snip
Date: 9 Mar 2004 08:23:34
Message: <404dc556$1@news.povray.org>
Thanks for the suggestion. I havn't had time to check it out yet. I spent
the last week working on skin texture. It looks to me, though, that your
hair system is limited to the hair styles available on that website. Yes?
No?
Steve shelby
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:zNAUvBAGfjRAFwk$@econym.demon.co.uk...
>   texture_map {
>                 interpolate 2}}]
> image.
> they work.
> Mike Williams
Date: 9 Mar 2004 14:13:45
Message: <8fz3bBADQhTAFw1N@econym.demon.co.uk>
>No?
There are other sites with hair for Poser figures, but DB2 are possibly
the best, and also...
>> they work.
Mike Williams
