POV-Ray : Newsgroups : povray.general : changing a box from one end to the other, is it possible? Server Time
16 Jan 2026 00:49:33 EST (-0500)
  changing a box from one end to the other, is it possible? (Message 1 to 3 of 3)
Subject: changing a box from one end to the other, is it possible?
Date: 27 Feb 2004 18:57:16
Message: <403fd95c@news.povray.org>
Is it possible to change to box (with four corners in one end) to have only
two corners in the other end?
And how do I do it?
Subject: Re: changing a box from one end to the other, is it possible?
Date: 27 Feb 2004 21:09:38
Message: <403FF85F.49C07FD2@hotmail.com>
> only two corners in the other end?
> And how do I do it?
It's called the prism object.  Read up on it in the docs.
John
Date: 1 Mar 2004 11:21:57
Message: <40436325@news.povray.org>
  Do you mean if you can scale any box-shaped object to appear as a prism
like you describe, or if you can create a shape with 5 faces like you
describe?
  In the first case the answer is no: You can't scale an object in such
non-uniform way.
  In the second case there are quite many possible solutions. I'm a bit
busy right now so I don't have the time to write some pov-code, but I'm
sure someone else will be willing to help with that. :)
