POV-Ray : Newsgroups : povray.general : Warning: Patch objects not allowed in intersection Server Time
12 Sep 2025 15:31:21 EDT (-0400)
  Warning: Patch objects not allowed in intersection (Message 1 to 10 of 11)
Subject: Warning: Patch objects not allowed in intersection
Date: 18 Feb 2004 16:20:55
Message: <4033d737@news.povray.org>
I received this error while doing a difference with a triangle within
a union (POV 3.5, NT4), yet it seems to have rendered fine, that
is, the semicircle was removed from the triangle. What did I do
incorrectly?
difference {
   union {
     cylinder { <-0.1,0.25,0> <0,0,0> 0.005 }
     cylinder { <0.1,0.25,0> <0,0,0> 0.005 }
     triangle { <0,0,0>, <-0.1,0.25.0>,  <0.1,0.25.0> }
  cylinder { <0,0.25, 0.1> <0,0.25,-0.1> 0.11 }
  pigment {rgb 1}
=Bob=
Subject: Re: Warning: Patch objects not allowed in intersection
Date: 19 Feb 2004 01:42:43
Message: <40345ae3@news.povray.org>
"=Bob=" <was### [at] threestrandscom> wrote in message
news:4033d737@news.povray.org...
> incorrectly?
> difference {
>    union {
>   pigment {rgb 1}
You have periods instead of commas before the Z member of your triangle
vectors.
Date: 19 Feb 2004 01:49:54
Message: <cpm8309ueh2h1fnfbrlagds1jkvgtoenr7@4ax.com>
On Wed, 18 Feb 2004 13:21:38 -0800, "=Bob=" <was### [at] threestrandscom>
No, 3.5 says it's a "Warning", not error.
3.6 says it's a "Parse warning", so...
Warning is a warning. It's for your knowledge.
> What did I do incorrectly?
For some cases patch object could work, for some couldn't. Since it is not
easy to decide it at parsing time, you are warned about possible problem.
Perhaps could be better formulated. Warnings are supposed to be informative
but short.
"6.5.6.4 Difference" chapter: "The component objects must have well defined
inside/outside properties. Patch objects are not allowed."
ABX
Date: 19 Feb 2004 01:56:39
Message: <40345e27@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:cpm8309ueh2h1fnfbrlagds1jkvgtoenr7@4ax.com...
> wrote:
Oy, so it wasn't the Z members after all :-)
<snip />
defined
Hey, I just saw this commercial where a human body had an ior and I figured
it must have been a patch. Can you add ior to patches when the inside is not
well defined?
Date: 19 Feb 2004 02:09:34
Message: <17o830hh0puv82u8762v7acf1nkibrsdmu@4ax.com>
> vectors.
That's one of the known technics making code shorter.
ABX
disc{z,-z#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e 1))/10-4#declare
e=e-1;#end#local e=26;5pigment{#local g=function(_){ceil(_)-_}function#local
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e)<O()O()>.01#
end}}}}{k(g(atan2(x,y)),g(ln(pow(x+y,2)+1e-5)),0)}}finish{ambient 1}}//ABX35
Date: 19 Feb 2004 02:16:50
Message: <ffo830lb8t537r034o3uo4i9a0saitho4t@4ax.com>
Raytracing with X-Rays ?
> Can you add ior to patches when the inside is not well defined?
Even lights can have negative colours.
Artistic purposes are unknown for us, technical nerds ;-)
ABX
Date: 19 Feb 2004 13:42:03
Message: <cjameshuff-C1CF01.13423919022004@news.povray.org>
In article <40345e27@news.povray.org>,
> well defined?
Using ior only requires that the shape be closed and that it has a
"clean" interior. When doing refracted rays, POV keeps track of
insideness by counting surfaces hit...it enters a sphere the first time
it hits it, and leaves it the second time. A mesh sphere will work
properly. A mesh sphere with holes in it, or with a stray triangle stuck
in the middle, will not render properly, but this is practically
impossible to test, so POV doesn't even try to detect it.
You can't bend a single patch into a shape that's useful for refraction,
but you can construct a shape out of patches that will render properly
with refraction. It won't work properly with some CSG operations, though.
http://tag.povray.org/
Date: 19 Feb 2004 17:35:47
Message: <2hea30letlpo0ku5tucghggn03fkvd2nfh@4ax.com>
>> vectors.
gulp
Andreas
Date: 19 Feb 2004 19:18:32
Message: <40355258$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-C1CF01.13423919022004@news.povray.org...
<snip />
Ah, I get it. Thank you Christopher!!!!
Date: 20 Feb 2004 05:18:33
Message: <4035def9@news.povray.org>
  Unless you use a specialized algorithm to determine the insideness of
the patch object, such as the 'inside_vector' in meshes does... :)
