POV-Ray : Newsgroups : povray.general : can I use POV from an external application? Server Time
20 Apr 2026 02:29:32 EDT (-0400)
  can I use POV from an external application? (Message 1 to 5 of 5)
Subject: can I use POV from an external application?
Date: 9 Feb 2004 02:59:38
Message: <40273dea$1@news.povray.org>
I would like to know how I can render a file from an external application.
Like a Visual basic one, for example. May be by giving some simple dos
command line?
Could you help me?
Thanks.
Gianluca
Subject: Re: can I use POV from an external application?
Date: 9 Feb 2004 03:10:19
Message: <Xns948A20057FE03tomatimporg@203.29.75.35>
"Gianluca Massaccesi" <gia### [at] tinit> wrote in
news:40273dea$1@news.povray.org:
> application. Like a Visual basic one, for example. May be by giving
> some simple dos command line?
> Could you help me?
pvengine.exe /NR /EXIT filename.pov
Season with switches(see docs for details) to your liking.
Tom
_________________________________
The Internet Movie Project
http://www.imp.org/
Date: 9 Feb 2004 03:42:16
Message: <402747e8@news.povray.org>
Many thanks for the suggestion.
I have tried the following line:
"C:\Programmi\POV-Ray for Windows v3.5\bin\pvengine.exe" /NR /RENDER
"C:\Programmi\POV-Ray for Windows v3.5\scenes\advanced\piece2.pov"
POV starts but it gives an erros, as it cannot fin the file. The file is
there, and it can be lauched successfully by the WIN interface.
Can you tell me where I am wrong?
There is anyway to avoid to let the interface opened/visible, while it is
rendering?
Thanks again.
Gianluca
"Tom Galvin" <tom### [at] imporg> ha scritto nel messaggio
news:Xns948A20057FE03tomatimporg@203.29.75.35...
> > Could you help me?
> Tom
> http://www.imp.org/
Date: 9 Feb 2004 03:45:47
Message: <402748bb@news.povray.org>
Following my previous message, here is the complete message given:
Roots tested:                16789   eliminated:                   0
Calls to Noise:              92388   Calls to DNoise:          72340
Smallest Alloc:                 25 bytes   Largest:            89524
Peak memory used:          3080584 bytes
Time For Trace:    0 hours  0 minutes   4.0 seconds (4 seconds)
    Total Time:    0 hours  0 minutes   4.0 seconds (4 seconds)
CPU time used: kernel 0.10 seconds, user 3.74 seconds, total 3.84 seconds
Render averaged 16686.16 PPS over 64000 pixels
POV-Ray finished
Preset INI file is 'C:\PROGRAMMI\POV-RAY FOR WINDOWS
V3.5\RENDERER\QUICKRES.INI', section is '[320x200, No AA]'.
Preset source file is 'C:\Programmi\POV-Ray for Windows
v3.5\scenes\advanced\piece2.pov'.
Persistence of Vision(tm) Ray Tracer Version 3.5 win32 (.icl)
  This is an official version prepared by the POV-Ray Team. See the
   documentation on how to contact the authors or visit us on the
   internet at http://www.povray.org/.
Copyright 1991-2002 POV-Ray Team(tm)
This Windows version by Christopher J. Cason
Parsing Options
  Input file: C:\Programmi\POV-Ray for Windows
v3.5\scenes\advanced\piece2.pov (compatible to version 3.5)
  Remove bounds........On  Split unions........Off
  Library paths: C:\Programmi\POV-Ray for Windows v3.5\INCLUDE
    C:\WINNT\Fonts
Output Options
  Image resolution 320 by 200 (rows 1 to 200, columns 1 to 320).
  Output file: piece2.bmp, 24 bpp (system format)
  Graphic display......On  (type: 0, palette: 3, gamma:  2.2)
  Mosaic preview......Off
  CPU usage histogram.Off
  Continued trace.....Off  Allow interruption..Off  Pause when done.....Off
  Verbose messages.....On
Tracing Options
  Quality:  2
  Bounding boxes.......On  Bounding threshold: 3
  Light Buffer.........On  Vista Buffer.........On  Draw Vista Buffer...Off
  Antialiasing........Off
Animation Options
  Clock value....   0.000  (Animation off)
Redirecting Options
  All Streams to console.........Off
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Possible Scene File Parser Initialization Error: Could not find file
'C:\Programmi\POV-Ray for Windows v3.5\scenes\advanced\piece2.pov'
Scene File Parser Initialization Error: Cannot open input file.
Returned from renderer with error status
> > Could you help me?
> Tom
> http://www.imp.org/
Date: 9 Feb 2004 04:33:37
Message: <402753f1@news.povray.org>
Sorry!
The sintax is correct but the file was not there.
If there is it works!
Thanks
"Gianluca Massaccesi" <gia### [at] tinit> ha scritto nel messaggio
news:402748bb@news.povray.org...
> POV-Ray finished
> Parsing Options
>     C:\WINNT\Fonts
> Output Options
done.....Off
> Tracing Options
>   Quality:  2
Buffer...Off
> Animation Options
> Redirecting Options
> > > Could you help me?
> > Tom
> > http://www.imp.org/
