POV-Ray : Newsgroups : povray.general : Chris Colefax's city generator Server Time
12 Jun 2026 10:20:42 EDT (-0400)
  Chris Colefax's city generator (Message 1 to 3 of 3)
Subject: Chris Colefax's city generator
Date: 31 Dec 2003 16:55:49
Message: <3ff345e5$1@news.povray.org>
... is quite cool.
http://www.geocities.com/SiliconValley/Lakes/1434/citygen.html
If Chris is reading these ng's,  I have a public request for a feature to
this generator.  One thing I noticed that when tinkering years ago was that
the city block near the origin is completely different depending on whether
you have one block or mulitple blocks on the scene.   Suppose I wanted to
set up some "action"  and do lots of tinkering at the origin block.  Then
for final render I might want to add a bloomin' city behind it.  How hard
would it be (for you/me) to change your city generator to make this change?
Subject: Re: Chris Colefax's city generator
Date: 1 Jan 2004 19:39:31
Message: <3ff4bdc3@news.povray.org>
that
whether
change?
The City Generator uses a number of random number streams to control
different aspects of the city.  One way to achieve what you want is to reset
the necessary streams for each block, e.g. create a custom city macro file
(a copy of City.mcr) and rewrite the city_building macro something like
this:
#macro city_building (Corner1, Corner2, Direction)
    #declare _CT_rand3 = seed(vlength(Corner1*100));
    #declare _CT_rand4 = seed(vlength(Corner1*100));
    #local BCentre = (Corner1 + Corner2)/2;
    #local BHeight = min_building_height +
rand(_CT_rand3)*(max_building_height - min_building_height);
    #if (BHeight > 0) city_assemble_building
(int(building_types*rand(_CT_rand3)), (Corner2-Corner1) +
y*BHeight, -y*90*Direction, BCentre + y*pavement_height) #end
This way the characteristics of each building will be determined by its
distance from the origin, and adding further city blocks around the centre
will not change the existing buildings.
Date: 2 Jan 2004 23:16:32
Message: <3ff64220@news.povray.org>
Cool thanks.  That it's doable gives me courage to try.  In the middle of
irtc anim rendering right now, but thanks greatly for the answer.
