POV-Ray : Newsgroups : povray.general : simple syntax question Server Time
12 Sep 2025 22:29:52 EDT (-0400)
  simple syntax question (Message 1 to 6 of 6)
Subject: simple syntax question
Date: 11 Dec 2003 15:47:14
Message: <3fd8d7d2@news.povray.org>
I'm very new to POVray, and using version 3.5 on Linux. In general, I'm
a C and C++ programmer, and am trying to do something in POVray that
would be a simple procedural call in C.
I'm creating a scene of a set of nodes and paths between nodes for
creation of a picture something like the "traveling salesman" problem. A
path is traced through a series of locations (nodes) on given paths
(edges), finding the minimum path that visits each node exactly once. It
looks something like a 3D chess board with selected edges being placed
between squares, and some squares missing.
I want to declare a global variable:
#declare Node_Center = < 0.0, 0.0, 0.0 >;
And then prior to calling a macro inside of an object {} that renders a
node icon based on location of Node_Center, I want to call another macro
(such as "Translate_Left") that alters the value of Node_Center in one
direction (partially desired because of different handedness of POVray
axis and the input data axis), taking into account a scale. The problem
is I cannot seem to find a way to actually alter the content of
Node_Center that is not an error. I have to alter the value of
Node_Center before calling:
object {
   Render_Node (Node_Center)
Then the outside application can write the scene file based on something
like a series of:
Translate_Left ()
object {
Translate_Up ()
object {
The application itself then merely knows to go left, right, up, or down,
and does not have to keep track of Node_Center, nor does the application
need to understand the difference in axis handedness or scaling between
data and POVray. Is it even possible to alter a global declaration like
this from outside of the object? If I can only do this from inside of an
object, how can I alter my global value prior to rendering the node's icon?
Subject: Re: simple syntax question
Date: 12 Dec 2003 00:40:42
Message: <$LF3+EANSV2$Ewj0@econym.demon.co.uk>
>object {
>like a series of:
>Translate_Left ()
>object {
>Translate_Up ()
>object {
I would have thought that the following syntax would work. What errors
are you getting?
#macro Translate_Left()
  #declare Node_Center = Node_Center - x;
#macro Translate_Up()
  #declare Node_Center = Node_Center +y;
Mike Williams
Gentleman of Leisure
Date: 12 Dec 2003 07:31:38
Message: <3fd9b52a@news.povray.org>
> >object {
> >like a series of:
> >Translate_Left ()
> >object {
> >Translate_Up ()
> >object {
> icon?
> are you getting?
> #end
> #end
This works. Prior to this I made the mistake of not using declare after
the variable was declared, a bit of a C-ism. But since it is really a
macro expansion, it isn't a lot like C, the use of declare each and
every modification of Node_Center does the job :)
Date: 12 Dec 2003 19:53:04
Message: <cjameshuff-1F15EF.19484412122003@netplex.aussie.org>
In article <3fd9b52a@news.povray.org>,
It sounds like you have a misunderstanding here. The #declare statement
is not a macro declaration. It declares an actual variable. After
"#declare A = 2+2;", "A" is a variable containing the value 4, not a
macro expanding to the string "2+2".
For modifying variables, the #declare or #local is necessary. This is
just a syntax issue, and has nothing to do with macros. (In MegaPOV,
there is a #set keyword specifically for modifying existing variables
without the possibility of accidentally creating a new one.)
http://tag.povray.org/
Date: 14 Dec 2003 17:30:30
Message: <3fdce486$1@news.povray.org>
Yes, you are correct, it was my C'ish background that the #declare style
would be a macro.
Not familiar with MegaPOV. However, this is where it again becomes
non-intuitive for C/C++ background...there is no need in those languages
to use something like #declare twice. This is why I called it a macro,
that I have to use #declare to essentially redeclare the same thing with
a new value. Even though it is a true variable, it seems I have to
essentially redefine it each change, which was hanging me up.
Date: 15 Dec 2003 17:21:27
Message: <cjameshuff-9F18A3.17212915122003@netplex.aussie.org>
In article <3fdce486$1@news.povray.org>,
Maybe you have some misconception of what a macro is. This is simply the
syntax POV uses...as you said, you have to redeclare a variable to
modify it. This is unrelated to whether it is a macro or not. It is a
variable, meaning a value of a specific type referred to by name. If you
assign 2*2 - 1 to a variable, that variable has the *value* 3, and knows
nothing about how you specified it.
A macro is an entirely different construct. Macros operate by text
substitution, modifying the actual code while its being parsed. When the
macro identifier is used in the scene, its contents replace its
identifier at the location of its use. If you gave a macro the
expression 2*2 - 1, its data would consist of that expression. The
expansion of that macro would then give exactly "2*2 - 1".
