POV-Ray : Newsgroups : povray.general : What causes these odd artifacts? Server Time
23 Nov 2025 14:12:56 EST (-0500)
  What causes these odd artifacts? (Message 1 to 8 of 8)
Subject: What causes these odd artifacts?
Date: 10 Dec 2003 06:46:09
Message: <3fd70781$1@news.povray.org>
Here is a very small scene which shows some odd artifacts. There should
be no coincident surfaces here - or is there? You can see surprisingly
more artifacts by removing the double slash before the second box. What
causes these and how can I get rid of them?
You can see the artifacts in the shadow of the superellipsoid.
light_source { <0,2,2> 1}
     location <0, 0.1, -0.5 >
union {
     box {<-0.25,-0.02,-0.25>,<0.25,0.0,0.25>}
     // box {<1,1,1>,<2,2,2>}
     superellipsoid { <0.4,0.4>
                       scale <0.22,0.015,0.22>
     pigment{ rgb 1}
Severi Salminen
Subject: Re: What causes these odd artifacts?
Date: 10 Dec 2003 07:04:29
Message: <oprzyrtszv0x9foi@news.povray.org>
On Wed, 10 Dec 2003 13:46:08 +0200, Severi Salminen
> camera {
> union {
>      pigment{ rgb 1}
> Severi Salminen
Looks like inaccuracy in the root solver, scaling the whole scene by 10
removes the artifacts.
Translating the superellipsoid slightly in the y-direction solves also the
problem.
The sturmian root solver could also help, but it can't be used (stated in
the doc 6.5.1.11  Superquadric Ellipsoid).
light_source{20*y,1}#macro _(M,X,Y,P)#macro L(N,D)#if(N)#declare
P=P+D;box{-
0.5,0.5translate z*mod(9*P.gray,4)pigment{rgb P}rotate 45*x+clock*y
translate
P}L(N-1,D)#end#end#if(M)L(mod(M,8)<mod(X,3)mod(Y,3)1>-1)_(div(M,8)div(X,3)div
(Y,3)P)#end#end _(2301603551,12850,60365,20*z-5*x)plane{y,-9pigment{rgb 1}}
Date: 10 Dec 2003 09:00:07
Message: <3fd726e7$1@news.povray.org>
> the problem.
> in the doc 6.5.1.11  Superquadric Ellipsoid).
Ok, thanks for your observations. In the meantime I'll just wait a
128bit version of POV-Ray :)
Severi Salminen
Date: 10 Dec 2003 12:10:07
Message: <Xns944DB8C512E64raf256com@204.213.191.226>
emp### [at] cchutfi news:oprzyrtszv0x9foi@news.povray.org
Btw, I suggest to create a macro that will i.e. generate smooth-mesh
imitating superquadric ellipsoids.
Why? I think that this object implementation is broken:
1) it renders terrible slow (about 10-20 times slower then i.e. torus)
especialy when pov must calculate intersections with it
2) it very often had problems/artifacts like mentioned above
3) both things get worse when using supperellipsoid in CSG
Date: 10 Dec 2003 12:13:57
Message: <3fd75455$1@news.povray.org>
Thanks for the suggestion! I'm still learning and don't know anything
about smooth meshes. But they might indeed work better. And I tried to
model a pillow using superellipsoids and it didn't work...
Severi Salminen
Date: 10 Dec 2003 12:18:38
Message: <Xns944DBA3712AFraf256com@204.213.191.226>
sev### [at] NOT_THISsibafi news:3fd75455$1@news.povray.org
I think that there was ready isosurface function generating a pillow, named
like maybe f_pillow ? try to search in help.
Date: 10 Dec 2003 12:42:03
Message: <rd2ka1-fab.ln1@triton.imagico.de>
Please don't pretend there is a bug if you don't have serious arguments.
    Something isn't broken just because it does not work as you expect
it. The three points you listed are completely natural if you know how
superellipsoids work.  If you don't like them - don't use them (and as
you can read up in the newsgroup archives there are good reasons for
using an isosurface version instead.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 10 Dec 2003 13:23:37
Message: <Xns944DC53B94FA6raf256com@204.213.191.226>
chr### [at] gmxde news:rd2### [at] tritonimagicode
Yes, this was my point - I realy do not like them :)
I agree there probably isn't a bug.
