POV-Ray : Newsgroups : povray.general : Arbaro 0.8 released Server Time
23 Nov 2025 14:12:11 EST (-0500)
  Arbaro 0.8 released (Message 1 to 1 of 1)
Subject: Arbaro 0.8 released
Date: 8 Dec 2003 08:43:55
Message: <3fd4801a@news.povray.org>
A new version 0.8 of Arbaro is released. See
  https://sourceforge.net/projects/arbaro/
Comparing with version 0.7 there are the following
major changes:
- pictures explaining the parameters
- direct POVRay invoking option
- using mesh output the tree consists only
  of two meshes: one with all the stems and another
  with all the leaves. (You can give the triangle
  number of a leaf using disc1 ... discN for the
  Leaf parameter, for special purposes you can use
  Leaf=shpere (spherical leaf), it's aproximated
  by an ikosaeder, see desert_bush.xml as an example)
Plans for the next versions:
0.9 - support multiple trunks (for bushes and shrubs)
    - add leaves that aren't totally flat - e.g. for palms
...1.0 - fix all small bugs and quirks
       - more realistic trunk (bumps and displaced lobes)
maybe later: blossom and fruits, more species, special
      features for coniferes, e.g. needles on all stem levels.
Wolfram Diestel <wol### [at] stelojdeFORIGU>
