POV-Ray : Newsgroups : povray.general : Help with a spherical container Server Time
4 Oct 2024 16:20:43 EDT (-0400)
  Help with a spherical container (Message 1 to 10 of 29)
Subject: Help with a spherical container
Date: 4 Nov 2003 19:38:38
Message: <3fa8468e@news.povray.org>
Hey, i had an idea for something pretty interesting but I am having problems
implementing it.  What i did was create a sphere with object media at the
origin with a radius of five. That part was easy enough, but placing the
lights is troubling me. I need the placement to be random, but at the same
time the lights need to be on the inside of the sphere. If they go outside,
they light the sphere itself and that destroys the scene. So can anyone help
me?
Thanks in advance.
Subject: Re: Help with a spherical container
Date: 4 Nov 2003 20:22:08
Message: <3fa850c0@news.povray.org>
#declare Seed = seed(0);
#declare LightLocation = 10*<rand(Seed), rand(Seed), rand(Seed)>-5;
#while(vlength(LightLocation) > 5)
  After the loop ends you will have a random point inside the sphere
of radius 5 in 'LightLocation'.
Date: 4 Nov 2003 20:33:38
Message: <3fa85372$1@news.povray.org>
Ok, cool. It works great now. Can you explain how that works?
news:3fa850c0@news.povray.org...
problems
the
same
> #end
M()}}
Warp -
Date: 4 Nov 2003 20:40:55
Message: <cjameshuff-618341.20403704112003@netplex.aussie.org>
In article <3fa850c0@news.povray.org>, Warp <war### [at] tagpovrayorg>
> #end
Or you could just use VRand_In_Sphere() in rand.inc.
http://tag.povray.org/
Date: 4 Nov 2003 20:44:08
Message: <cjameshuff-E27010.20435004112003@netplex.aussie.org>
In article <3fa85372$1@news.povray.org>,
Find a random point in a 10x10x10 box. If the point is outside the
radius-5 sphere, find another random point in the box. Repeat until you
have a random point in the sphere.
The method the include file uses is a bit more complex, but is overall a
bit faster...the loop method can require several attempts before it
turns up a useable point.
Date: 4 Nov 2003 20:48:55
Message: <3fa85707@news.povray.org>
  This is true, but relevant only if you are going to place hundreds or
thousands of points inside the sphere... :)
  Honestly, I didn't remember the macro in the standard include file.
If I had, I would have suggested it.
Date: 4 Nov 2003 21:06:42
Message: <3fa85b32$1@news.povray.org>
this is kinda funny, i changed the amount of lights im going to use from 25
to 250 (and increased the radius to 500) and its been parsing for the last
15 minutes o.O
im just going to go ahead and stop it now and try the function in the
standard include.
problems
the
same
> #end
M()}}
Warp -
Date: 4 Nov 2003 21:11:20
Message: <3fa85c48$1@news.povray.org>
nah, i cant resist the urge to see how long it takes.
20 minutes and counting...
"Wesley Parker" <wes### [at] verizonnet> wrote in message
news:3fa85b32$1@news.povray.org...
25
> 15 minutes o.O
> standard include.
> problems
> the
the
> same
> > #end
> M()}}
> Warp -
Date: 4 Nov 2003 21:41:41
Message: <cjameshuff-B78040.21412304112003@netplex.aussie.org>
In article <3fa85b32$1@news.povray.org>,
> 15 minutes o.O
It shouldn't take *that* long to parse, it may actually be done parsing
and busy working on light buffers. If it takes too long or runs out of
memory, try turning off light buffers. Or maybe you made a mistake in
modifying the code...it will take a very long time to find random points
in a 5-unit sphere when you use random points from a 1000-unit box.
Date: 5 Nov 2003 01:09:18
Message: <kurtzlepirate-B9FAE6.07091605112003@netplex.aussie.org>
In article <3fa8468e@news.povray.org>, "Wesley Parker" <wes### [at] verizonnet>
> me?
> Thanks in advance.
hi,
you can about that :
take a rayon
take a random number from 0 to 360
take an other random number from +90 to -90
then just convert polar coordonates from this 3 number to rectangular <x,y,z>
pretty simply
