POV-Ray : Newsgroups : povray.general : Isosurface, or perhaps log() help Server Time
13 Sep 2025 01:07:12 EDT (-0400)
  Isosurface, or perhaps log() help (Message 1 to 6 of 6)
Subject: Isosurface, or perhaps log() help
Date: 23 Oct 2003 19:07:23
Message: <3f985f2b$1@news.povray.org>
I was playing with functions, trying to learn about isosurfaces, when I
found something that looked like a "black hole".  But I noticed what
looked like some strange shadows or reflections on it, and I cleaned up
my code and have some questions on it.
Basically, it's the log function.  In an image with the variable "close"
  defined as false you can see the problems as black shapes in the hole.
With close set to true, the camera is moved right into the hole and the
sides are not smooth.
Is this just a limitation of the algorithm used to create isosurfaces?
Or am I doing something wrong?
Two more questions
Can the ?: (conditional) operator be used in a function?
Can vlength() be used in a function?  (It kept complaining about the "<"
symbol on the vector I passed it).
Thanks.  Code follows:
// Persistence of Vision Ray Tracer Scene Description File
// File: i_test.pov
// Vers: 3.5
// Desc: Testing Isoserfaces - trying to get what I want
// Date:
// Auth: Tom A.
#version 3.5;
global_settings {
   assumed_gamma 1.0
#declare close = false;
   direction 1.5*z
#if( close)
   location  <1.0, 4, -1.0>look_at   <0.0, 0.0,  0.0>
#else
   location  <0.0, 20.5, -53.50>look_at   <0.0, 0.0,  0.0>
} // camera
sky_sphere {   pigment {  Black } }
light_source { <0,200, 0>  color White }
isosurface
{ function { (y-  log( sqrt(x*x+z*z) )*5)
     contained_by { box { -15, 15 } }
   #if (close) // a sort of black whole type grid
    texture{
      pigment{ gradient z color_map{ [.02 White ] [.02 Clear ] } scale .25 }
      finish{ ambient .4 }
    texture{
      pigment{ gradient x color_map{ [.02 White ] [.02 Clear ] } scale .25}
   #else
     pigment{ gradient y scale 7 }
Subject: Re: Isosurface, or perhaps log() help
Date: 23 Oct 2003 19:15:28
Message: <3f986110$1@news.povray.org>
Without looking very closely at the code, I predict that you can solve the
problem by either reducing the "accuracy" or increasing the "max_gradient".
Check the documentation for each.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 23 Oct 2003 19:56:26
Message: <cjameshuff-AAFC6F.19541923102003@netplex.aussie.org>
In article <3f985f2b$1@news.povray.org>,
This sounds like typical artifacts of the isosurface intersection
solving algorithm. If so, it has nothing directly to do with the log()
function, it is caused by your function having too high of a gradient.
Using higher quality settings (mainly a higher max_gradient) will reduce
or eliminate these artifacts.
No. The select() function gives the same functionality, however.
http://povray.org/documentation/view/137/#s06_01_03_06
No. Neither can any other vector functions. User defined functions have
no concept of "vectors". The only way you can get a vector value from
one is to use a transform, pigment, or spline function, and you can't
perform mathematical operations on vectors within a function.
A full listing of what you can use in functions is here:
http://povray.org/documentation/view/140/
http://tag.povray.org/
Date: 24 Oct 2003 05:36:44
Message: <3F98F3ED.2030504@informatik.uni-freiburg.de>
The log function is here used in a range containing zero. The derivative
of log at zero is infinite, so the gradient is unbounded and no max_gradient
can suffice.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 24 Oct 2003 11:20:32
Message: <3f994340$1@news.povray.org>
Thank you, and the the others who answered my questions.
Tom A.
Date: 24 Oct 2003 18:59:00
Message: <cjameshuff-00B2E3.18565224102003@netplex.aussie.org>
In article <3F9### [at] informatikuni-freiburgde>,
> can suffice.
Right, but it reaches infinity at a line along the y axis, and the
surface quickly moves outside the container object. A high enough
max_gradient should get rid of most of the artifacts that show up. For
this isosurface, max_gradient 12 almost completely eliminated the
problems.
