POV-Ray : Newsgroups : povray.general : IE6 Script Error Server Time
31 Mar 2026 08:18:04 EDT (-0400)
  IE6 Script Error (Message 1 to 3 of 3)
Subject: IE6 Script Error
Date: 12 Oct 2003 15:54:28
Message: <3f89b174@news.povray.org>
I can't believe I haven't had this error before on a 6 month old box.
Could it be a security setting in IE6?
If so, any pointers to help me?
Norton AntiVirus was the last programme installed 2 weeks ago.
From Pov's menu bar:
Scene->index: light, light fading, light source, light sources (and
other words)
Each gives the following window
> Internet Explorer Script Error
> Line:    1
> Char:    1
> Error:   Object doesn't support this property or method
> Code:    0
> URL:     mk:@MSITStore:C\PROGRAM%20FILES\POV-RAY%
>          20FOR%20WINDOWS%20v3.5
>          \help\povray35.chm::/output/povdoc_192.html
>     Do you want to continue running scripts on this page?
Sometimes ..._269.html or 127.html or 193.html
Version 3.5.icl.win32, WinXP SP1, P4 2.8G, 512MB.
No problems on a Win98 SP2 machine with NAV 2003 - I get the "select a
subentry" prompt
TIA
Alf
Subject: Re: IE6 Script Error
Date: 12 Oct 2003 19:37:18
Message: <3f89e5ae$1@news.povray.org>
Program ended abnormally on 12/10/2003 15:53, Due to a catastrophic Alf
Peake error:
Did you download hotfix 828750 (Microsoft Security bulletin MS03-040) ?
If yes,  it's probably the follwoing caveat:
Caveats:
If you have not installed the updated HTML Help control from Knowledge Base
article 811630, you will not be able to use some HTML Help functionality after
applying this update. In order to restore that functionality, users need to
download the updated HTML Help control (811630). Users should also note that
when the latest version of HTML Help is installed, the following limitations
will occur when a help file is opened with the showHelp method:
     * Only supported protocols can be used with showHelp to open a web page or
help (.chm) file.
     * The shortcut function supported by HTML Help will be disabled when the
help file is opened with showHelp This will not affect the shortcut
functionality if the same CHM file is opened by the user manually by
double-clicking on the help file, or by through an application on the local
system using the HTMLHELP( ) API.
Date: 13 Oct 2003 09:46:16
Message: <3f8aaca8@news.povray.org>
Hi Francois
"Francois Labreque" <fla### [at] videotronca> wrote in message
news:3f89e5ae$1@news.povray.org...
MS03-040) ?
Don't know :-/ Went on-line 1st time 3 weeks ago and box went mad with
live-updates!
need to
That fixed the problem. Thank you.
Alf
http://www.peake42.freeserve.co.uk/
http://www.qsl.net/gw3srg/
