I'm not sure that this discovery adds much to the stockpile of useful POVRay
techniques, but I thought I'd share it anyway.
I wanted to directly warp an isosurface -- not add or subtract a noise
function, but apply the "black_hole," "turbulence," etc. to the isosurface
function itself.
By going through Mike Williams' "Isosurface Tutorial,"
http://www.econym.demon.co.uk/isotut/index.htm, I came up with the
following (but don't blame him if I missed some incredibly easy method of
doing the same thing):
Use the function in question as a pigment, but run it through a "high-low"
filter, so that it doesn't repeat itself for values >1 and < -1. If the
function has a threshold of 0, I do this:
#declare My_F = function { stuff };
#declare Warped_F =
function {
function {min(max(-0.5, My_F(x,y,z)),0.5) + 0.5}
warp { warping stuff }
isosurface { function { Warped_F(x,y,z).gray - 0.5 }
threshold 0
other isosurface stuff
Depending on the function, sometimes I've had to use "0.5 -
Warped_F(x,y,z).gray" .
Question: Is there an easier way of directly "warping" an isosurface?
Question #2 (I'll answer this): Why not just add/subtract a pigment?
(Answer: I don't know. Maybe I'm just being difficult.)
>function itself.
>#declare Warped_F =
> function {
> pigment {
> threshold 0
OK, now I see that I could simply use "pattern" instead of "pigment" and not
need the .gray at all.
(Don't know how I missed this, it's right in Mike Williams' tutorial.)
One of the fun things I do is to warp the isosurfaces
by d multiplying (adding etc)
the co-ordinates by another function. e.g.
f_wrinkles(x * f_wrinkles(x,y,z),
y * f_wrinkles(x,y,z),
z * f_wrinkles(x,y,z))
Its more flexible than plain warping, but slow
at least until someone patches warping to take functions :-)
Dave
