POV-Ray : Newsgroups : povray.general : Arbaro 0.6 - tree generation tool Server Time
13 Sep 2025 03:25:24 EDT (-0400)
  Arbaro 0.6 - tree generation tool (Message 1 to 2 of 2)
Subject: Arbaro 0.6 - tree generation tool
Date: 26 Sep 2003 06:00:15
Message: <3f740e2e@news.povray.org>
The tree generation tool Arbaro is now ported to Java.
(So speed is ok now).
You will find the release 0.6 on the sourceforge server here:
  http://sourceforge.net/projects/arbaro/
Beside porting to Java, some more features are added
and bugs fixed. Lobes and Mesh output are added since the
0.4 release. There are more tree definition files.
A dozen of rendered example trees you will find here:
  http://arbaro.sourceforge.net/
With interested people I would like to discuss some
specific problems, like:
- would it better for Povray memory usage to put leaves in
  a big mesh instead of a union of discs
- a splitted trunk looks somewhat strange, should the
  trunk radius be smaller for clones or is this a problem
  with mesh creation
- would a more evenly splitting algorithm be preferable
    Wolfram.
Wolfram Diestel <wol### [at] stelojdeFORIGU>
Subject: Re: Arbaro 0.6 - tree generation tool
Date: 26 Sep 2003 07:14:43
Message: <3f741fa3@news.povray.org>
  A mesh should be definitely better.
  I don't know if it will make a big difference in memory usage/rendering
time if you have one single tree, but if you copy the same tree several
times in your scene it should definitely have a great impact in memory
usage.
