POV-Ray : Newsgroups : povray.general : Function woes Server Time
20 Apr 2026 11:05:40 EDT (-0400)
  Function woes (Message 1 to 5 of 5)
Subject: Function woes
Date: 16 Sep 2003 11:47:27
Message: <3f67308f$1@news.povray.org>
Can anybody please tell me what's wrong with the following code? POV
stops at the "<" and says that it expected an operand instead. How else
can I measure the distance between two points?
#declare Gauss =
   function( x, y, z, Centre, Spread ) {
     exp( vlength( <x, y, z> - Centre ) / 2*pow( Spread, 2 ) )
/ martin
Subject: Re: Function woes
Date: 16 Sep 2003 11:55:30
Message: <r8cemv4vmt4baukikc4r6c54p56hkj7e9q@4ax.com>
On Tue, 16 Sep 2003 17:47:26 +0200, Martin Magnusson
You used not allowed syntax.
> POV stops at the "<" and says that it expected an operand instead.
And this is according to function syntax listed in documentation. If you could
look into syntax frame at http://www.povray.org/documentation/view/140/ there
is not vector mentioned in allowed _function_ syntax.
> How else can I measure the distance between two points?
Using f_r() function: f_r(X1-X2,Y1-Y2,Z1-Z2).
ABX
Date: 17 Sep 2003 04:14:21
Message: <3f6817dd$1@news.povray.org>
OK, thanks. Now I have other problems though...
First, I declare a function like this:
#declare Gauss =
function(X1, Z1, S) {
   exp( -1 * ( pow(x-X1, 2) + pow(z-Z1, 2) ) / (2*pow(S, 2)) )
Then I'd like to use it in an isosurface, but it gives unexpected
results. Using the macro below does what I want. I would expect the two
lines inside the function{} to be equal, but when using the one that is
commented out here, I just get a flat surface. Can somebody tell me why?
#macro Node( Centre_x, Centre_z, Spread )
isosurface
   function {
     //y - Gauss( Centre_x, Centre_z, Spread )
     y - exp( -1 * ( pow(x-Centre_x, 2) + pow(z-Centre_z, 2) ) /
(2*pow(Spread, 2)) )
   contained_by {
     sphere{ <Centre_x, 0, Centre_z>, Spread*5 }
   pigment{ rgbt < 1, 0, 0, 0.5> }
camera
   location <3, 8, -10>
   look_at <0, 1, 0>
light_source
   <10000, 10000, -10000>
   rgb 1
Node( 0, 0, 1 )
Date: 17 Sep 2003 04:41:07
Message: <987gmv88j224bu0ajmhqc3dr3s5pclbbuc@4ax.com>
On Wed, 17 Sep 2003 10:14:23 +0200, Martin Magnusson
You did wrong assumption that x flows magically from isosurface to Gauss
function. x used within function code is basically reference to first
parameter of _current_ function, y is second one, z is third one. So you have
to write your code as follow:
#declare Gauss =
function(x,y,z,X1, Z1, S) {
isosurface
   function {
     y - Gauss( x,y,z, Centre_x, Centre_z, Spread )
   contained_by {
I did not checked this but should work now as expected.
ABX
Date: 17 Sep 2003 08:27:35
Message: <3f685337@news.povray.org>
In article <987gmv88j224bu0ajmhqc3dr3s5pclbbuc@4ax.com> , ABX
Actually, this isn't correct.  x, y and z can appear anywhere in the
parameter list.  However, they also exist when they are not defined in the
parameter list.  In that case, they will be 0.0 and thus constant.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
