POV-Ray : Newsgroups : povray.general : parsing problem in POVRay Server Time
23 May 2026 00:02:00 EDT (-0400)
  parsing problem in POVRay (Message 1 to 6 of 6)
Subject: parsing problem in POVRay
Date: 2 Sep 2003 16:02:13
Message: <3f54f745$1@news.povray.org>
I think I found a potential bug that I couldn't find in the know bugs,
so I report here, I hope it's the right group. Here is the code :
#macro Return_Int (A)
   #if (A>0)
     A
   #else
     0
#local Var1=Return_Int (5);
You don't need any light or camera, POV-Ray complains that there should
be a ';' at line 3 after the returned 'A' which I wouldn't expect. When
I write :
   #if (A>0)
     A;
   #else
     0;
It works, but I see that more like a workaround than a correct syntax.
I hope it helps improving our worshiped POV,
JC
Subject: Re: parsing problem in POVRay
Date: 2 Sep 2003 16:22:03
Message: <RJeY8FAQsPV$Ewew@econym.demon.co.uk>
>   #if (A>0)
>     A
>   #else
>     0
>   #end
>#end
The conventional way of writing this so that POV accepts it would be to
put it in brackets, like this:
   #if (A>0)
     A
   #else
     0
#local Var1=(Return_Int(5));
Mike Williams
Gentleman of Leisure
Date: 2 Sep 2003 16:27:49
Message: <3f54fd45@news.povray.org>
>    #if (A>0)
>      A
>    #else
>      0
>    #end
> #end
  This is a typical place for making a mistake in the SDL syntax (and
perhaps would reserve an entry in the povQ&T page).
  The right way of doing this is:
   #if (A>0)
     #local retval = A;
   #else
     #local retval = 0;
   retval
  The reason for this is because how the parser works... But it's a bit
too complicated for me to explain this late at night. :)
Date: 2 Sep 2003 16:29:02
Message: <3f54fd8e@news.povray.org>
  There's no need if you write the macro properly (as I explained in the
other post).
Date: 2 Sep 2003 17:56:57
Message: <3f551229$1@news.povray.org>
Would you mind doing so someday in
the early morning? :-)
I'm just curious, that's all. Doing it like you
described for some time now, but never
got the technical answer why that is better...
Tim
Tim Nikias v2.0
> >    #if (A>0)
> >      A
> >    #else
> >      0
> >    #end
> > #end
>    #if (A>0)
>      #local retval = A;
>    #else
>      #local retval = 0;
>    #end
>    retval
> #end
x]
Warp -
Date: 3 Sep 2003 02:13:24
Message: <3f558684@news.povray.org>
For beeing in computer programming I think I understand why the parser
works this way, thanks for giving me way to make it work fine, it is the
way every function returning value should be writen anyway, so that's
cool, POV-Ray is actually enforcing good practices.  :-)
JC
>>   #if (A>0)
>>     A
>>   #else
>>     0
>>   #end
>>#end
>    #if (A>0)
>      #local retval = A;
>    #else
>      #local retval = 0;
>    #end
>    retval
> #end
