POV-Ray : Newsgroups : povray.general : Transform help please Server Time
16 Jan 2026 12:20:58 EST (-0500)
  Transform help please (Message 1 to 10 of 10)
Subject: Transform help please
Date: 28 Aug 2003 17:31:24
Message: <3f4e74ac@news.povray.org>
Please help an old man whose brain is off-line ;-)
Wanted: a prism from 5 points on a plane.
Why doesn't this always work?
TIA
Alf
camera{ location <-1, 2,-4> look_at <0,0,0> }
light_source{ <-100,100,-100> 1 }
#declare OK = 1; // 0/1 = Not OK/OK.
#if (OK = 1)
   #declare P1 = < 1.170639, 1.170639, 1.170639>;
   #declare P2 = < 1.894104, 0.000000, 0.723495>;
   #declare P3 = < 1.894104, 0.000000,-0.723495>;
   #declare P4 = < 1.170639, 1.170639,-1.170639>;
   #declare P5 = < 0.723495, 1.894104, 0.000000>;
#else
   #declare P1 = <-1.170639, 1.170639, 1.170639>;
   #declare P2 = <-1.894104, 0.000000, 0.723495>;
   #declare P3 = <-1.170639,-1.170639, 1.170639>;
   #declare P4 = < 0.000000,-0.723495, 1.894104>;
   #declare P5 = < 0.000000, 0.723495, 1.894104>;
#declare Avg = (P1+P2+P3+P4+P5)/5; // Face center
#declare FaceN = vcross(P1-P2, P1-P3); // Face normal
// I think the error is here?
#declare Up = <-degrees( atan2( FaceN.z, FaceN.y) ),
                0,
                degrees( asin( FaceN.x/vlength(FaceN) ) )>;
union{ // Show original points.
   sphere{ P1, 0.1 }
   sphere{ P2, 0.1 }
   sphere{ P3, 0.1 }
   sphere{ P4, 0.1 }
   sphere{ P5, 0.1 }
   pigment{ rgb <1,0,1> }
// Rotate 5 points to be above and parallel to y-plane.
#declare Pa = vrotate(P1, Up);
#declare Pb = vrotate(P2, Up);
#declare Pc = vrotate(P3, Up);
#declare Pd = vrotate(P4, Up);
#declare Pe = vrotate(P5, Up);
// Show points on y-plane.
union{
   sphere{ <Pa.x, 0, Pa.z>, 0.1 }
   sphere{ <Pb.x, 0, Pb.z>, 0.1 }
   sphere{ <Pc.x, 0, Pc.z>, 0.1 }
   sphere{ <Pd.x, 0, Pd.z>, 0.1 }
   sphere{ <Pe.x, 0, Pe.z>, 0.1 }
   pigment{ rgb <0,1,1> }
// Now transform a prism to match original points.
prism{ -0.05, 0.05, 5+1,
   <Pa.x, Pa.z>,
   <Pb.x, Pb.z>,
   <Pc.x, Pc.z>,
   <Pd.x, Pd.z>,
   <Pe.x, Pe.z>,
   <Pa.x, Pa.z>
   pigment{ rgb <1,1,0> }
   translate y*vlength(Avg) // y*(distance from <0,0,0>)
   rotate -Up
Subject: Re: Transform help please
Date: 29 Aug 2003 03:01:36
Message: <3f4efa50@news.povray.org>
I'm not quite sure what you want to do, but I have a few remarks that
could give you some hints:
- Are you sure the face's points are coplanar ? (I guess you are, but
it's still worth asking)
- It is generaly better in POV scripts if you can use vectorial (cross
products, projections, transforms.inc macros and stuff like that)
formulaes instead of trigonometric, because it's clearer and it's not as
error prone. Basically I don't what the Up vector should be, so it's
difficult to point out a potential error.
Good luck, I know these kind of bugs are really annoying,
JC
> TIA
> Alf
> #if (OK = 1)
> #else
> #end
>                 0,
>    sphere{ P1, 0.1 }
>    sphere{ P2, 0.1 }
>    sphere{ P3, 0.1 }
>    sphere{ P4, 0.1 }
>    sphere{ P5, 0.1 }
> union{
>    <Pa.x, Pa.z>,
>    <Pb.x, Pb.z>,
>    <Pc.x, Pc.z>,
>    <Pd.x, Pd.z>,
>    <Pe.x, Pe.z>,
>    <Pa.x, Pa.z>
>    rotate -Up
Date: 29 Aug 2003 07:04:08
Message: <3f4f3328@news.povray.org>
Hi
"JC (Exether)" <no### [at] spamfr> wrote in message
news:3f4efa50@news.povray.org...
that
Basicly, making a polyhedron with thick faces. Well, OK, a buckyball.
Yes.
(cross
I can never remember vectorial operations like vcross :-/ but can
manage trig with a pencil & paper most times.
Up is +y. I want to rotate any vector to point up.
> Good luck,
Thanks
Alf
Date: 29 Aug 2003 09:56:10
Message: <3f4f5b7a@news.povray.org>
Speaking is easy, doing is better, so I did it.  :-)
It seems to be what you wanted.
JC
TIA
Alf
#include "transforms.inc"
#if (OK = 1)
#else
#declare Up = transform { Reorient_Trans(FaceN, y) };
   sphere{ P1, 0.1 }
   sphere{ P2, 0.1 }
   sphere{ P3, 0.1 }
   sphere{ P4, 0.1 }
   sphere{ P5, 0.1 }
#declare Pa = vtransform(P1, Up);
#declare Pb = vtransform(P2, Up);
#declare Pc = vtransform(P3, Up);
#declare Pd = vtransform(P4, Up);
#declare Pe = vtransform(P5, Up);
union{
   <Pa.x, Pa.z>,
   <Pb.x, Pb.z>,
   <Pc.x, Pc.z>,
   <Pd.x, Pd.z>,
   <Pe.x, Pe.z>,
   <Pa.x, Pa.z>
   transform { Reorient_Trans(y, FaceN) }
Alf Peake wrote:
> Hi
> that
> Yes.
> (cross
>>Good luck,
> Thanks
> Alf
Date: 29 Aug 2003 10:45:46
Message: <3f4f671a@news.povray.org>
news:3f4f5b7a@news.povray.org...
Thank you. That looks OK.
I realy should spend some time looking thru' the new includes in 3.5.
Alf
Date: 29 Aug 2003 21:39:16
Message: <3f500044@news.povray.org>
Why not just define a solid model (centred at the origin) and subtract a
smaller from a bigger?
Hm, my http://www.ogre.nu/source/platon.inc has most of what you'd need
for that;
#declare Soccer = intersection {
	#declare i=0;
	#while (i<6)
		plane { SixAxes[i], RP }
		plane { -SixAxes[i], RP }
		#declare i = i+1;
	#end//while
	#declare i=0;
	#while (i<10)
		plane { TenAxes[i], RH }
		plane { -TenAxes[i], RH }
		#declare i = i+1;
	#end//while
difference { object {Soccer} object {Soccer scale 0.95} }
...I just don't know the appropriate ratio between RP and RH
(though I suppose I could derive it).
...On another hand, this sort of transform may be just what I'd need for
an idea that has kicked around in back of my mind: a gothic Fuller dome.
Anton Sherwood, http://www.ogre.nu/
Date: 30 Aug 2003 09:52:16
Message: <3f50ac10@news.povray.org>
"Anton Sherwood" <new### [at] ogrenu> wrote in message
news:3f500044@news.povray.org...
subtract a
That's too easy :-) I wanted to be able to manipulate each face. Just
doodling.
need
> for that;
I'll look at that. Thanks.
OT: I was playing with data I found at
http://www.ccl.net/cca/data/fullerenes/index.shtml
Started with C30 data until I figured not all faces have coplanar
vertices. I'll stay with C20 data for now, maybe try C540 later.
I see from your website you like this subject :-) but I'm just
"passing by".
Alf
Date: 31 Aug 2003 21:30:11
Message: <3f52a123@news.povray.org>
Hi Alf,
your declaration of the Up variable is correct, but to undo a
   rotate Up
which is the same as
   rotate Up.x*x // or <Up.x, 0, 0>
   rotate Up.y*y // or <0, Up.y, 0>; in your code, Up.y=0
   rotate Up.z*z // or <0, 0, Up.z>
you will have to undo these rotations in *reverse* order, i.e.
   rotate -Up.z*z
   rotate -Up.y*y
   rotate -Up.x*x
so the mistake is in the next-to-last line: replace
   rotate -Up
by
   rotate -Up.z*z
   rotate -Up.x*x
(rotate -Up.y*y is not required here because Up.y=0)
This will work as intended.
   Sputnik
Date: 1 Sep 2003 00:27:04
Message: <cjameshuff-46883C.00270301092003@netplex.aussie.org>
In article <3f52a123@news.povray.org>,
>    rotate -Up.z*z
>    rotate -Up.y*y
>    rotate -Up.x*x
Or "transform {rotate Up inverse}". Besides being shorter, it says
exactly what it's doing and is far less error-prone, especially when
you're editing the code.
Even better would be to declare the transformation. That way, you only
need to edit one bit of code to change it.
http://tag.povray.org/
Date: 1 Sep 2003 09:27:45
Message: <3f534951$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
Yes, I had figured that. I was put off because it worked OK around 50%
of the time.
Thank you for that. Another item I was unaware of. Realy must RTFM
again.
Alf
