POV-Ray : Newsgroups : povray.general : LCDs and gamma Server Time
18 Sep 2025 04:21:27 EDT (-0400)
  LCDs and gamma (Message 1 to 6 of 6)
Subject: LCDs and gamma
Date: 22 Aug 2003 06:56:26
Message: <3f45f6da@news.povray.org>
If you have an LCD display, what display_gamma do you use in your
povray.ini?
I'm using 1.4 but this produces an image which is too dark when viewed
on a crt. I found other threads here on this subject but no useful
answers.
With assumed_gamma 1 in a pov file, I'm unable to match renders on an
LCD box and crt box. "Another knot (48k)" posted in p.b.i was rendered
on LCD box and has bright colours.
I have an NEC LCD1760NX but the specs don't give its gamma.
Alf
http://www.peake42.freeserve.co.uk/
http://www.qsl.net/gw3srg/
Subject: Re: LCDs and gamma
Date: 22 Aug 2003 17:32:17
Message: <3f468be1$1@news.povray.org>
news:3f45f6da@news.povray.org...
> povray.ini?
I'm using display_gamma=assumed_gamma = 1.
Not perfect, but much better than the default...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 22 Aug 2003 20:32:56
Message: <3f46b638$1@news.povray.org>
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3f468be1$1@news.povray.org...
> > povray.ini?
Mine is Display_Gamma=2.2. Although, I had set it as 2.3 before based on how
I saw the test GIF on LCD. Whether incorrect or not, it seems to be okay
until I forget to set assumed_gamma 1.0 in the scene file.
Bob H.
Date: 23 Aug 2003 10:51:01
Message: <3f477f55@news.povray.org>
"Hughes, B." <omn### [at] charternet> wrote in message
news:3f46b638$1@news.povray.org...
de
your
> > > povray.ini?
based on how
Hmm.. thats quite a range for 2 responses.
I believe LCDs are linear so should have a gamma of 1 but this doesn't
seem to work for me :-/
Alf
Date: 24 Aug 2003 17:04:25
Message: <3f492859@news.povray.org>
Alf Peake <alf### [at] peake42freeservecouk> wrote in message
news:3f477f55@news.povray.org...
Having never completely understood gamma on my CRT,  I'm certainly not going
to pretend to understand it on an LCD, except to say that I  don't think
they're even remotely the same.
I've finally settled on display_gamma = 1,  assumed_gamma = 1 for my CRT,
but on my girlfriends LCD it is always much brighter.  The same file on her
LCD needs assumed_gamma 1.275-1.325 to look the same.
RG
Date: 25 Aug 2003 09:35:12
Message: <3f4a1090@news.povray.org>
"gonzo" <rgo### [at] lansetcom> wrote in message
news:3f492859@news.povray.org...
> on her LCD needs assumed_gamma 1.275-1.325 to look the same.
If you don't share source or images, gamma doesn't matter. As you have
found, it matters when you want to share and have others see what
_you_ see.
Alf
