POV-Ray : Newsgroups : povray.general : Write macro-generated objects to file? Server Time
20 Apr 2026 18:00:07 EDT (-0400)
  Write macro-generated objects to file? (Message 1 to 7 of 7)
Subject: Write macro-generated objects to file?
Date: 22 Jul 2003 11:46:04
Message: <3f1d5c3c@news.povray.org>
Hi there!
When populating a scene with loads of macro-generated objects, I thought
it would be a nice idea to run those time-consuming macros only once,
write their "return values" (in this case: unions of triangles) to an
.inc file and re-use this file when further experimenting with the
scene. However, I couldn't figure out a way to write those objects to a
file - the #write directive apparently only accepts strings, numbers and
vectors.
Does anybody have a clue how one could save macro-generated objects to a
file - i.e. use PovRay for creating its own .inc files?
Thanx in advance -
	Torsten
Subject: Re: Write macro-generated objects to file?
Date: 22 Jul 2003 12:13:00
Message: <3F1D628B.3D8D14B2@gmx.de>
Torsten Crass wrote:
> Hi there!
> vectors.
You can find some samples for using the #write directive in the standard
include file 'shapes.inc'.  As you said #write supports strings, floats
and vectors.  Since all objects consist of such elements you can write
them quite easily.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 22 Jul 2003 12:31:19
Message: <3f1d66d7$1@news.povray.org>
Hi Christoph!
> them quite easily.
Uhm, well... yes and no. Of course it is possible to assemble all
keywords and parameter values which define an object into a file - if
you can retrieve them one by one. But what about a union that comes out
of a macro, and whose sub-objects have been created and randomly
transformed by further sub-macros, and so forth?
Something like a to_string(OBJECT) function would be really handy! But
there isn't one, is there?
Regards -
	Torsten
Date: 22 Jul 2003 13:13:59
Message: <3F1D70D6.36FCB076@gmx.de>
Just add writing code in your macros wherever an object is created.
There won't be - objects are not always stored internally as they are
written in script.
Date: 22 Jul 2003 15:45:18
Message: <3f1d944e@news.povray.org>
3f1d5c3c@news.povray.org...
> Hi there!
Look for the advanced/blocks examples in the demo scenes for instance.
Other examples can be found in my tree and grass macros
http://www.oyonale.com/ressources/english/sources01.htm and pipe macros
http://www.oyonale.com/ressources/english/sources08.htm
G.
- Graphic experiments
- Posters
Date: 23 Jul 2003 06:37:49
Message: <3f1e657d$1@news.povray.org>
Hi Christoph,
<sigh>if it must be...</sigh> I was just hoping I could use the same
macros for creating both .inc files and ready-to-use objects for my scene.
Thanx anyway -
	Torsten
Date: 23 Jul 2003 08:24:19
Message: <Xns93C19331EFECFseed7@povray.org>
> scene.
I may be misunderstanding you sihgs, but you can use one macro/inc-file
for that.
#macro SomeMacro (a,b,c, FileName)
  #if(file_exists(FileName))
    #include FileName
    #local WriteFile=0;
  #else
    #if(strlen(FileName)!=0)
      #local WriteFile=1;
      #fopen GeneratedObjectsFile FileName write
    #else
      #local WriteFile=0;
  // generate an object here,
  // use the WriteFile variable to check
  // wether it should be written to file or not
When you call the macro with a FileName="" no file will be written.
When you call a macro with a FileName="something" it will be checked
wether the file already exists. In that case the existing file will be
parsed. If it doesn't exist a new file will be written.
Ingo
