POV-Ray : Newsgroups : povray.general : Render time: ultrafine dxf-->tri vs. bicubic Server Time
27 Dec 2025 20:16:51 EST (-0500)
  Render time: ultrafine dxf-->tri vs. bicubic (Message 1 to 8 of 8)
Subject: Render time: ultrafine dxf-->tri vs. bicubic
Date: 12 Jul 2003 16:02:53
Message: <3f10696d$1@news.povray.org>
I've finally decided to hunker down and do model some complex backgrounds.
In so doing, I'm considering which povray objects are the most efficient.
For example, I know making everything out of isosurfaces would be really
slow.   I'm assuming "modelled"  laboratory equipment then exported to
triangles would render much faster than asking povray to do the complex CSG.
Right now, I'm trying to figure out which renders & parses faster:
1) a bicubic patch
2) a really dense triangle mesh of the same object (Hamapatch export to
DXF).
Actually, I have two side questions about modellers:
i) I'm surprised at the limited number of triangles that show up in a
hamapatch export to DXF.  There's a setting of "4" subsurfaces: I'd have
liked to try 16 or more.  Any tips?
ii) Does POVLAB work with WinXP?   For about  a decade now, I've had trouble
getting the program to run at all....
Subject: Re: Render time: ultrafine dxf-->tri vs. bicubic
Date: 12 Jul 2003 16:04:50
Message: <3f1069e2$1@news.povray.org>
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:3f10696d$1@news.povray.org...
CSG.
What I meant here is:
One could make a complex object using boxes & cylinders in povray with
dozens of CSG statements.  I'm assuming for render time, using a formal
modelling program like Moray, POVLAB, or Hamapatch should win hands down in
terms of render time.  Am I correct.
Date: 12 Jul 2003 17:29:54
Message: <3f107dd2@news.povray.org>
I've never used hamapatch, but I use autocad a lot... dxf format leaves much
to be desired.  If you can export as 3ds you might get better results.
Douglas C. Eichenberg
dou### [at] nlsnet
http://www.getinfo.net/douge
Date: 12 Jul 2003 18:52:02
Message: <3f109112@news.povray.org>
Greg M. Johnson <gregj;-)565### [at] aolcom> wrote in message
> 1) a bicubic patch
> DXF).
Don't know about render times, guess my models aren't that complex, the
stuff I've exported from hamapatch seemed to render about the same as
modeling in POV, the biggest difference was the parse time.  I've found that
parse times on either bicubic patch or mesh is considerably longer than CSG.
Lately I find I only use Hamapatch when I want to do something I simply
don't know how to do in CSG.
Have you tried Wings3d? ( http://www.wings3d.com/ ) It's quite a capable
modeler on its own, and I also find it useful for subdivision on stuff I've
modeled in other programs.   If you have something modeled in Hamapatch,
rather than subdividing the whole object, export as .obj, import into Wings
and subdivide only the parts that need fine detail. Then convert to POV
using Poseray.
RG
Date: 12 Jul 2003 20:31:54
Message: <cjameshuff-224BF3.19291512072003@netplex.aussie.org>
In article <3f1069e2$1@news.povray.org>,
> 1) a bicubic patch
> DXF).
Answer: it depends. The patch can precompute a lot of data, making
memory and speed about equal to mesh. That precomputation takes parse
time, bringing it closer to that of a high res mesh. How close? I don't
know, and it probably depends on what settings you use.
No. You're asking POV to replace a relatively simple boolean operation
on a group of primitives with a search through a much larger group of
triangles.
For some cases it could be correct, but for others it is not. Boxes,
spheres, and cylinders are all quite fast, you would have to get a
pretty complex CSG before a mesh equivalent would be faster. If you're
using a complex and slow isosurface or a sweep of thousands of spheres,
a precomputed mesh becomes a better option. Of course, the mesh will be
much slower to parse.
You're most likely "prematurely optimizing". You should look for a
faster way if it is too slow, but scenes are usually slow for reasons
other than CSG and data parsing.
http://tag.povray.org/
Date: 13 Jul 2003 15:34:51
Message: <3f11b45b$1@news.povray.org>
Yes, I'm trying to choose the optimum tool before I even start making
things.
Thanks for the advice all.  Maybe I'll stick with hamapatch.
Okay Chris, so what's the likely biggest contributor to slow scenes?
Date: 13 Jul 2003 16:19:08
Message: <cjameshuff-4D43BC.15163413072003@netplex.aussie.org>
In article <3f11b45b$1@news.povray.org>,
It depends on the scene. With isocacti.pov, it's isosurfaces. That scene
could be a lot faster with mesh or patch geometry. (Of course, since the
purpose of the scene is to demo isosurfaces, that's not really an option)
For newdiffract.pov, it's photons. Making the geometry in that scene out
of meshes or patches would most likely only slow it down further.
Meshes are mainly used in modellers for these reasons: it is trivial to
do a high-speed, low quality render using wireframe or a scanline
renderer. If you are doing a scanline final render, you have to convert
it to triangles anyway. And using a mesh opens up the possibility of
doing displacements and other manipulation that you can't easily do on
primitives. And finally, most other modellers use meshes.
If you're modelling something like a test tube, it's a simple CSG of two
spheres and two cylinders (and maybe a torus to round the rim). You
aren't doing anything that needs meshes, and the shape will probably
render more quickly as a CSG. But if you're doing something like a car
body or human figure, a mesh is the best way to go.
Subject: RE: Render time: ultrafine dxf-->tri vs. bicubic
Date: 13 Jul 2003 17:15:07
Message: <3f11cbdb$1@news.povray.org>
As you seem to work with DXF, there is a simple solution.
You only have to put the sPatch plugins in a folder called
"export plugins" under Hamapatch main folder.
When you want to export your object select from the menu:
File -> sPatch plugin -> DXF or Layered DXF (wolfie).
When it exports, it give you options for a higher subdivision
level than the Hamapatch in-built exporter.
You can get the sPatch plugins (and more utilities) here:
www.geocities.com/hamapatch/links/hamautil.html
Hope this helps.
Bye
Txemi Jendrix
http://www.txemijendrix.com
