POV-Ray : Newsgroups : povray.general : a simple question about File I/O Server Time
24 Nov 2025 00:28:40 EST (-0500)
  a simple question about File I/O (Message 1 to 8 of 8)
Subject: a simple question about File I/O
Date: 1 Jul 2003 12:26:59
Message: <3f01b653@news.povray.org>
How to read a lot of data from a file into a N*M array?
Thank a lot.
Subject: Re: a simple question about File I/O
Date: 1 Jul 2003 12:42:38
Message: <9td3gvcapg56dpk1qgbo20idgu2bnsi7mh@4ax.com>
On Wed, 2 Jul 2003 00:26:48 +0800, "aaaz123456" <aaa### [at] yahoocomtw> wrote:
Running loop with necessary number of passes to read N*M elements which is
simplest to understand when realized as N loops of M loops of simple reading.
#local N=...;  // fill with
#local M=...;  // favorite dimensions
#local Array=array[N][M];
#fopen MyFile "myfile.txt" read
#local n=0;
#while (n<N)
  #local m=0;
  #while (m<M)
    #read(MyFile,Array[n][m])
    #local m=m+1;
  #local n=n+1;
#fclose MyFile
Look at http://www.povray.org/documentation/view/147/ for further description of
used directives
ABX
Date: 1 Jul 2003 17:56:20
Message: <3f020384$1@news.povray.org>
You might also want to take a look at my
I/O Macros. Even if you don't want to use
them, they can provide a nice example
for you to dissect and study how to do it.
ABX's reply has already given the HOW,
so I'm just providing an example... :-)
Tim Nikias v2.0
Email: Tim### [at] gmxde
> Thank a lot.
Version: 6.0.495 / Virus Database: 294 - Release Date: 30.06.2003
Date: 1 Jul 2003 22:31:04
Message: <3f0243e8@news.povray.org>
I use the following loops to read data ,
but get a error message,that is "Parse error : Expected ' undeclared
indentifier' ,empty array found instead"
Why?
Thanks a lot .
> #local N=3;  // fill with
> #local M=3;  // favorite dimensions
> #local n=0;
> #while (n<N)
>   #local m=0;
>   #while (m<M)
>     #local m=m+1;
>   #end
>   #local n=n+1;
> #end
> #fclose MyFile
Date: 2 Jul 2003 02:17:09
Message: <5it4gv8jev6o6191jm5cs2b6pn21hut5om@4ax.com>
On Wed, 2 Jul 2003 10:30:53 +0800, "aaaz123456" <aaa### [at] yahoocomtw> wrote:
> Why?
Have you checked at which iteration it stops ? First ? Then before loops assign
value to any element of array to describe expected type of all array elements.
For example:
#local Array[0]0]=0;
Moreover you can introduce error checking inside loop:
   #ifdef(MyFile)
   #else
     #error concat("Can't read element Array[",str(n,0,0),",",str(m,0,0),"]")
ABX
Date: 2 Jul 2003 02:54:49
Message: <7+2ixHAlGoA$EwBb@econym.demon.co.uk>
>Why?
>Thanks a lot .
>> #local n=0;
>> #while (n<N)
>>   #local m=0;
>>   #while (m<M)
>>     #local m=m+1;
>>   #end
>>   #local n=n+1;
>> #end
>> #fclose MyFile
Add this line before the loop and it works
  #local Array[0][0] = 0;
It looks like #read is failing to instantiate the array, so you have to
do it yourself first.
Mike Williams
Gentleman of Leisure
Date: 2 Jul 2003 12:43:28
Message: <3f030bb0@news.povray.org>
Finally, I use the loop which is like the following loop.
I don't get any problem ,but I don't know why I can't use ABX's way to
write my loop.
Anyway, thank you.
#declare N=23431;  // fill with
#declare M=3;  // favorite dimensions
#declare Ar=array[N][M];
#fopen MyFile "data.txt" read
#declare n=0;
#while (n<N)
  //#declare m=0;
  //#while (m<M)
    #read(MyFile,a,b,c)
    #declare Ar[n][0]=a/100 ;
      #declare Ar[n][1]=b/100 ;
        #declare Ar[n][2]=c/100 ;
   // #declare m=m+1;
  //#end
  #declare n=n+1;
#fclose MyFile
Date: 2 Jul 2003 12:49:12
Message: <0036gvkmv34e50atu0hk4oo25atceg9vdp@4ax.com>
On Thu, 3 Jul 2003 00:43:16 +0800, "aaaz123456" <aaa### [at] yahoocomtw> wrote:
> write my loop.
Is your input data correct? In particular, are numbers comma separated ?
ABX
