POV-Ray : Newsgroups : povray.general : Parametric object with shadow gets black Server Time
21 Apr 2026 11:03:42 EDT (-0400)
  Parametric object with shadow gets black (Message 1 to 10 of 10)
Subject: Parametric object with shadow gets black
Date: 18 Jun 2003 13:08:59
Message: <3ef09caa@news.povray.org>
Just came from visualizing the strength of the magneric field in
a cylindrical cavity when I wanted to do the final rendering
without the no_shadow keywoard. (I am using it for speed's sake
when testing).
However, it turned out that the complete object gets black in that
case. Is this a bug or a self-shadowing problem?
What can I do against that?
(Quality setting was +Q9, of course...)
Wolfgang
Image (with no_shadow keywoard):
http://www.cip.physik.uni-muenchen.de/~wwieser/cavity3.png
Code:
#include "functions.inc"
global_settings { assumed_gamma 2.2 }
light_source { <0,1,0>*20, rgb <2,2,2>/2 }
light_source { <0.2,1,-0.8>*20, rgb <2,2,2>/1.7 }
#declare f_besselJ = function { internal(81) }
#declare f_besselJD = function { internal(82) }
#declare f_CAVITY = function { internal(83) }
#declare m=3;
#declare param_obj =
parametric {
        function { u*sin(v) }
        //function { 25*sqrt(pow(sin(m*v)*f_besselJ(u,0,0,m),2)+
        //      pow(cos(m*v)*m/u*f_besselJD(u,0,0,m),2)) }
        function { 25*f_CAVITY(u,v,0,m) }
        function { u*cos(v) }
        <0.00000001,0>, <15,2*pi>
        contained_by {  sphere { 0, 15 }  }
        precompute 16 x,y,z
        //no_shadow
        scale 0.2
object {
        param_obj
        texture { pigment { color rgb <0,1,0> } }
        rotate -20*y rotate -20*x scale 1.4 translate -0.2*y
plane { y,-3.2  pigment { rgb .6 } }
camera {  location <0,0.3,-1>*8.3 up y  look_at <0,0,0> }
Subject: Re: Parametric object with shadow gets black
Date: 18 Jun 2003 16:33:04
Message: <3ef0cc80@news.povray.org>
  You should really use functions by their official names. The internal()
ID numbers are reserved and should not be used (because they can change
at any time with a new version, without any notice, and can break old
scenes).
  I tried this scene with POV-Ray 3.5 and it says
Parse Error: Function 'internal(81)' does not exist.
  Are you using some kind of patched version?
Date: 19 Jun 2003 10:31:21
Message: <3ef1c936@news.povray.org>
> scenes).
The reason is just the same as the reason for the error below:
Correct. Because POVRay official version does not know the
Bessel J function -- and if you saw that function, you know why I have
to code it in C directly into POV source code...
Cheers,
Wolfgang
----------<fnintern.cpp>---------------
// Include GNU scientific library (GSL):
#include "/usr/local/numerics/include/gsl/gsl_sf_bessel.h"
inline DBL _f_besselJ(DBL x,int m)
        return(gsl_sf_bessel_Jn(m,x));
inline DBL _f_besselJD(DBL x,int m)
        double eps=0.00001;
        double vA=gsl_sf_bessel_Jn(m,x-eps);
        double vB=gsl_sf_bessel_Jn(m,x+eps);
        return((vB-vA)/(2.0*eps));
DBL f_besselJ(DBL *ptr, unsigned int fn) // 81
        return(_f_besselJ(PARAM_X,int(PARAM(0)+0.5)));
DBL f_besselJD(DBL *ptr, unsigned int fn) // 81
        return(_f_besselJD(PARAM_X,int(PARAM(0)+0.5)));
DBL f_CAVITY(DBL *ptr, unsigned int fn) // 82
        int m=int(PARAM(0)+0.5);
        double tmpA=sin(m*PARAM_Y)*_f_besselJ(PARAM_X,m);
        double tmpB=cos(m*PARAM_Y)*m/PARAM_X*_f_besselJD(PARAM_X,m);
        return(hypot(tmpA,tmpB));
Date: 19 Jun 2003 16:44:20
Message: <3ef220a4@news.povray.org>
  It's difficult to test your scene if it doesn't work in the official
version... :)
Date: 20 Jun 2003 16:59:45
Message: <3ef375c0@news.povray.org>
> version... :)
Okay, so here is a version which can be rendered on official version.
I replaced the Bessel functions with sin():
The problem is still there -- please have a look at it.
Try using better accuracy and you may SIGSEGV POVRay...
Wolfgang
#declare m=3;
parametric {
        function { 15*sqrt(pow(sin(m*v)*sin(u/2)/3,2)+
                pow(cos(m*v)*m/u*sin(u/2)/3,2)) }
        <0.001,0>, <15,2*pi>
        precompute 12 x,y,z
        accuracy 0.000001
        no_shadow  // <----------------- REMOVE THIS LINE
        scale 0.2
        rotate -20*y
        rotate -20*x
        scale 1.4
        translate -0.2*y
Date: 20 Jun 2003 17:03:27
Message: <3ef3769e@news.povray.org>
Wolfgang Wieser wrote:
>> version... :)
> accuracy 0.000001
Pardon, this accuracy is already too "good". To see the
problem with the shape getting black, leave away "accuracy" and
"no_shadow".
Wolfgang
Date: 20 Jun 2003 19:17:05
Message: <3ef395f0@news.povray.org>
  This may be worth posting a bug report, as it happens to me as well.
  As for the problem, I don't really know what's going on, sorry.
Date: 21 Jun 2003 04:36:23
Message: <Xns93A16C79CD544seed7@povray.org>
It will not solve the parametric object problem, but may get you a working
scene; param.inc at http://members.home.nl/seedseven/
Ingo
Date: 21 Jun 2003 12:12:35
Message: <3ef483f2@news.povray.org>
Yes...
As you can read on povray.programming, I also found out the cause
of the bug last night. But I don't know the apropriate fix.
Damn. Seems somehow, every point on the surface is considered
to be in heavy shadow?
Wolfgang
Date: 21 Jun 2003 12:42:07
Message: <cjameshuff-659F8E.11313921062003@netplex.aussie.org>
In article <3ef483f2@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
Or the normal calculations are getting screwed up. I was getting this
for a while with a patch I'm currently working on...zero length normal
vectors don't normalize well.
http://tag.povray.org/
