POV-Ray : Newsgroups : povray.general : To those using LSSM... (if any) Server Time
3 Mar 2026 05:50:11 EST (-0500)
  To those using LSSM... (if any) (Message 1 to 4 of 4)
Subject: To those using LSSM... (if any)
Date: 5 Jun 2003 19:07:40
Message: <3edfcd3c@news.povray.org>
I've once again uploaded a small update of the
system. In order to save parsing time, most
Macros will now load their data "JIT", which
means "Just In Time". Only when the data
really needs to be accessed or modified will
it be loaded (still only once as before though ;-),
otherwise it will be left alone.
AFAIK no errors should occur, if they do, just
give me a note with which macro it happens, and
use the older system until I've fixed that. As always,
the Macros stay backward compatible, so no
fussing with rewriting scenes.
Tim
Tim Nikias v2.0
Email: Tim### [at] gmxde
Subject: Re: To those using LSSM... (if any)
Date: 6 Jun 2003 13:27:48
Message: <3ee0cf14$1@news.povray.org>
I'll be pleased to see a speed increase. That's always nice. You can expect
more people to use the LSSM than those posting here. As for myself, I have
tried it and it works perfectly. I hope to post an animation using your
system. At the moement I'm trying to learn C++ so POV-Ray is temporarely on
ice (it's all sparetime projects).
Best regards,
Hugo
Date: 6 Jun 2003 20:37:56
Message: <3ee133e4@news.povray.org>
Good to know that some lurkers DO talk. :-)
Tim Nikias v2.0
expect
on
> Best regards,
> Hugo
Date: 6 Jun 2003 22:33:03
Message: <3ee14edf$1@news.povray.org>
PS: That wasn't meant as an offence. The "lurker" was
used in regard to "more people ... than those posting".
I plan on doing some more work on the LSSM, in order
to do even more JIT-Loading, at the expense of some
more #if statements...
I noticed that the loading sucks in larger scenes, like
used for one of my later images, DripDrop. I placed
several different timed LSS_Drops, and since I've
been using 50 pre-image steps with a large resolution,
each drop would load forever. Now, for a still, this
can't be helped, but I've ran it as an animation for a time
to grab the correct frame, the loading was unnecessary
for drops which weren't or already have been placed.
So I changed that, and went on doing that for other
macros as well. I guess I can make some other macros
even faster with more excessive usage of that.
Tim Nikias v2.0
> expect
have
> on
> > Best regards,
> > Hugo
