POV-Ray : Newsgroups : povray.general : possible difference bug Server Time
27 Dec 2025 23:51:00 EST (-0500)
  possible difference bug (Message 1 to 10 of 15)
Subject: possible difference bug
Date: 2 Jun 2003 09:56:38
Message: <3edb5796$1@news.povray.org>
I am doing the difference of two cubes. I expect the first cube to have a
hole where the second cube is. When I render the scene, the second cube is
visible. From what I have seen with differences, this seems like a bug.
//scene used to create this bug:
#include "textures.inc"
// ############ BEGIN #####################
//  location  <-6, 12, -50.05>
//  look_at   <-6, 12, -25.05>
//location <5,3,-11.05>
//look_at <5,3,-8.05>
location <5,3,-0.05>
look_at <5,3,-11.05>
light_source {
    <-6, 30, -60.05>
    color rgb <1, 1, 1>  // light's color
// house cube
difference {
    box {
        <-10, -1, -10>,  // Near lower left corner
        <10,15,10>       // Far upper right corner
            //MJHouse
            Red_Marble
            scale  .25
            rotate y*90
    box { <4,-1,-9.875>, <7, 4, -10.125> texture { White_Marble } }
} //end of difference
Subject: Re: possible difference bug
Date: 2 Jun 2003 10:03:37
Message: <l4mmdvsj3j82f1vjc3h7bd8khkg7m3eelr@4ax.com>
On Mon, 2 Jun 2003 09:56:39 -0400, "Mario" <ant### [at] spamcopnet> wrote:
>    box {
This "-1" cause two walls on the same plane. You probably want something like
    box { <4,-1.01,-9.875>,
for second box. Do you know why ?
ABX
Date: 2 Jun 2003 10:04:24
Message: <3edb5968$1@news.povray.org>
I'd like to add I'm using povray 3.5 on a Win2000 machine.
"Mario" <ant### [at] spamcopnet> wrote in message
news:3edb5796$1@news.povray.org...
> camera {
> light_source {
>     <-6, 30, -60.05>
> // house cube
> difference {
>     box {
>         texture {
>             //MJHouse
>             Red_Marble
>             scale  .25
>             rotate y*90
Date: 2 Jun 2003 10:06:10
Message: <3edb59d2$1@news.povray.org>
No I don't   :-(
But I do remember in the past having to do that for other scenes
"ABX" <abx### [at] abxartpl> wrote in message
news:l4mmdvsj3j82f1vjc3h7bd8khkg7m3eelr@4ax.com...
wrote:
> >    box {
like
> ABX
Date: 2 Jun 2003 10:11:27
Message: <3edb5b0f$1@news.povray.org>
Look for "coincidence surfaces" somewhere... :-)
Tim Nikias v2.0
Email: Tim### [at] gmxde
> No I don't   :-(
Date: 2 Jun 2003 10:14:31
Message: <5qmmdvsfecfc69k4feb71pv07h0qo15jpp@4ax.com>
On Mon, 2 Jun 2003 10:06:11 -0400, "Mario" <ant### [at] spamcopnet> wrote:
> No I don't   :-(
documentation: "3.3.6.1 Co-incident Surfaces"
http://www.povray.org/documentation/view/46/#s03_03_06_01
ABX
Date: 2 Jun 2003 10:22:45
Message: <3edb5db5$1@news.povray.org>
Thanks....
I think I saw that when I started with povray, but I probably thought "I
would never use a difference. That's too advanced for me"
*sigh*
news:5qmmdvsfecfc69k4feb71pv07h0qo15jpp@4ax.com...
wrote:
> > No I don't   :-(
> ABX
Date: 2 Jun 2003 10:34:57
Message: <3edb6091$1@news.povray.org>
I made that change, and I still don't see a hole in the first cube.
Any other suggestions?
wrote:
> >    box {
like
> ABX
Date: 2 Jun 2003 10:51:18
Message: <ivomdvg0pe9pfdhrp3ve9pt9leqso56jg4@4ax.com>
Put your camera to look into correct wall of box. Or reorient box to show hole.
ABX
Date: 2 Jun 2003 11:23:49
Message: <3edb6c05$1@news.povray.org>
hole.
Below I have copied the updated scene I am using.
Now what appears to be happening is that the differnce is creating a
"tunnel" into the first cube, with the "end of the tunnel" being the same
color as the second cube. This is odd because I thought all objects were
hollow. I expected to see a rectangular hole punched into the first cube,
and being able to look inside of the first cube.
location <5,3,-15.05>
  #if (frame_number < 361)
    rotate <0,360*clock,0>
light_source {
    <-6, 30, -60.05>
light_source {
    <5,3,-5.05>
// house cube
difference {
    box {
            //MJHouse
            Red_Marble
            scale  .25
            rotate y*90
            // this is only done for the difference of the house cube
        // front door
        box { <4,-1.01,-10.01>, <7, 4, -9> texture { White_Marble } }
} //end of difference for the house cube
