![](/i/fill.gif) |
Calculate its perpendicular first. Any three points define a plane, and
that plane has a perpendicular vector that is often called a "normal". Rotate
the triangle so that its normal is aimed at the camera location.
Cheers!
Chip Shults
![](/i/fill.gif) |
![](/i/fill.gif) |
Sir Charles W. Shults III <aic### [at] cfl rr com> wrote:
> Rotate
You should have given some hint on how to do this (it's not that trivial,
after all).
For a way, see the documentation about transforms.inc (specially about
the Reorient_Trans() macro).
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
