POV-Ray : Newsgroups : povray.general : Rotate to face camera Server Time
31 Mar 2026 20:05:07 EDT (-0400)
  Rotate to face camera (Message 1 to 3 of 3)
Subject: Rotate to face camera
Date: 26 May 2003 23:19:25
Message: <3ed2d93d$1@news.povray.org>
Should be an easy question but the brain doesn't want to think.  How do I
rotate a 2D face or triangle so that it faces the camera?
Skip
Subject: Re: Rotate to face camera
Date: 27 May 2003 01:24:13
Message: <3ed2f67d$1@news.povray.org>
Calculate its perpendicular first.  Any three points define a plane, and
that plane has a perpendicular vector that is often called a "normal".  Rotate
the triangle so that its normal is aimed at the camera location.
Cheers!
Chip Shults
Date: 27 May 2003 07:24:06
Message: <3ed34ad6@news.povray.org>
Sir Charles W. Shults III <aic### [at] cflrrcom> wrote:
> Rotate
  You should have given some hint on how to do this (it's not that trivial,
after all).
  For a way, see the documentation about transforms.inc (specially about
the Reorient_Trans() macro).
