POV-Ray : Newsgroups : povray.general : Focal blue problems Server Time
24 Nov 2025 06:01:51 EST (-0500)
  Focal blue problems (Message 1 to 5 of 5)
Subject: Focal blue problems
Date: 17 May 2003 10:27:19
Message: <3ec646c7$1@news.povray.org>
I'm trying to do a scene with two objects, looking along z, one at z=-5
(which I want to be in focus) and the other at about z=30 (which is out of
focus).
Camera is set:
 perspective
 angle 45.0000
 right < 1.0, 0, 0>
 up 1.47*y
 location cameralocation
 look_at <0,2,0>
 aperture 0.5
 blur_samples 10000
 focal_point<0,0,-5>
Even using that many blur samples, there are still artifacts in the distant
object.
Any ideas on how to get a smoother blur on the distance object?
Subject: Re: Focal blue problems
Date: 17 May 2003 10:56:00
Message: <3ec64d80$1@news.povray.org>
"Andrew Rowson" <pov### [at] growsecom> wrote in message
news:3ec646c7$1@news.povray.org...
> focus).
> Camera is set:
> camera {
>  perspective
>  angle 45.0000
>  right < 1.0, 0, 0>
>  up 1.47*y
>  look_at <0,2,0>
>  aperture 0.5
>  blur_samples 10000
>  focal_point<0,0,-5>
distant
> object.
Sorry, I should add that stupidly small variance and a confidence value of 1
still give a grainy blur.
Subject: Re: Focal blur problems
Date: 18 May 2003 22:22:19
Message: <3ec83fdb@news.povray.org>
Do you have a image to show the graininess? A crop of the particular part
would suffice. Post it to the povray.binaries.images group if you do,
please. I get acceptable results using default confidence and variance at
100 samples. Perhaps yours is a specific circumstance or large rendering?
The problem wouldn't seem to be the camera's aspect ratio, at least.
Date: 21 May 2003 14:15:06
Message: <web.3ecbc05f7e2294662a3ff2e70@news.povray.org>
Yes, post a sample image.  But from the sounds of this, I ran into this same
problem three or four years ago with focal blur in POV 3.1.  The problem is
the adc_bailout.  What this does is says that if after so many samples, a
new sample probably (or can't) change the color by more than such an
amount, then stop tracing rays.
The even bigger problem is that adc_bailout had a bug that basically resets
it to the default 1/255.0 every time you render an image.  I finally
reported the bug a couple months ago, and it's patched in 3.51, but I don't
know if there's a binary patch yet.  However, if you have the source code, I
can help you make the changes necessary to make the adc_bailout work.  Just
set it to 0, and artifacts like this should disappear (assuming that's what
you ran into).
Another option is to post the source in povray.text.scene-files, and I can
render it with my "fixed" version to verify if that is indeed the problem.
Date: 23 May 2003 13:26:37
Message: <3ece59cd$1@news.povray.org>
"Retsam" <nomail@nomail> wrote in message
news:web.3ecbc05f7e2294662a3ff2e70@news.povray.org...
same
is
resets
don't
I
Just
what
> you ran into).
I managed to fix this by specifying the varience as 0. Looks fine now.
