POV-Ray : Newsgroups : povray.general : Radiometry, photometry, candela, lux, etc... Server Time
28 Dec 2025 01:36:45 EST (-0500)
  Radiometry, photometry, candela, lux, etc... (Message 1 to 10 of 16)
Subject: Radiometry, photometry, candela, lux, etc...
Date: 13 May 2003 18:51:15
Message: <3ec176e3$1@news.povray.org>
Hi, I'm a newbie, and my english is very poor.
Sorry...
Exist a method (or macro, or tutorial, etc...)
to use Povray  for a "technic" simulation of artificial light?
I mean the simulation with the radiometry (or photometric) value of
a lamp (power, light intensity, or Photometric Solid, etc...).
Thanks,
             Manuel
Subject: Re: Radiometry, photometry, candela, lux, etc...
Date: 14 May 2003 01:55:07
Message: <hdm3cv04q470368qmoub0ubg36jphttrhc@4ax.com>
On Wed, 14 May 2003 00:57:06 +0200, "Manuel" <mba### [at] tiscalinetit>
Try Jaime's realistic light simulation macros (lightsys3)at
http://www.ignorancia.org/t_lightsys.php
Hope it helps.
Peter Popov ICQ : 15002700
Date: 14 May 2003 05:12:30
Message: <3ec2087e$1@news.povray.org>
> Hope it helps.
Great!!
Thanks!!!!
Date: 14 May 2003 09:50:05
Message: <web.3ec248f5a14066c9bef0bd7d0@news.povray.org>
Best way to use POV-Ray light simulation is to multiply light source color
with real light luminance (cm/m^2). Then set fade_distance using following
formula:
  sqrt(pi * A) / pi
Real world fade_power is 2. Because POV-Ray doesn't have dynamic range
compression, this isn't enough. I recommend you to define two adjusting
variables "Gamma" and "Max_Luminance" to make dynamic range compression.
Gamma is the gamma used to compress image dynamic range and Max_Luminance
is the luminance (cd/m^2) where pixel luminance at range 0..1 is "1".
Max_Luminance controls image brightness. When using these variables you can
calculate light source color multiplier using formula:
  pow(light_source_luminance / Max_Luminance, Gamma)
And global Fade_Power to *all* light sources by using formula:
  (ln(-exp(-ln(2) * Gamma) + 2) + ln(2) * Gamma) * 2 / ln(3)
To simulate photograph dynamic range compression I think that Gamma should
be ln(0.5)/ln(0.18) because gray card which reflects 18% of light looks
half bright.
Light source color luminance (without multiplier) must be one. Good starting
value for Max_Luminance is 50. Light source colours luminances without
multiplier must be one. Example for white light, light color is <1, 1, 1>.
Because you probably want to make other light sources than omnidircetional,
you need to simulate light distribution using spotlights. If light source
is flat, use spotlight radius -90 falloff 90 tightness 1 for cosine
falloff.
I don't recommend to use Jaime's lightsys because it doesn't use physically
accurate lightning. (Sorry Jaime).
Matti
Date: 14 May 2003 14:40:18
Message: <20030514204026.556cf8b0.jaimevives@ignorancia.org>
On Wed, 14 May 2003 09:47:33 EDT
> physically accurate lightning. (Sorry Jaime).
  Of course! Lightsys doesn't simulates lightning... :)
Jaime Vives Piqueres
Date: 15 May 2003 16:05:26
Message: <3ec3f306@news.povray.org>
Thanks again.
And (excuse my ignorance) about the radiosity?
I must include it for a good simulation?
Ehm...have you a sample scene that I can study?
I'm new to pov 3.5, and I only know roughly the old version...
thx,
          Manuel
"Matti Karnaattu" <nomail@nomail> ha scritto nel messaggio
news:web.3ec248f5a14066c9bef0bd7d0@news.povray.org...
> formula:
>   sqrt(pi * A) / pi
can
> half bright.
starting
omnidircetional,
> falloff.
physically
> Matti
Date: 20 May 2003 12:55:03
Message: <web.3eca5cc0a14066c984d065310@news.povray.org>
Absolutely. Use it with #default { finish { ambient 0 } }
I use these newsgroups from netcafe now, but I can put scene to net some
day.
Matti
Date: 21 May 2003 18:39:57
Message: <3ecc003d$1@news.povray.org>
> day.
Thx,
   I'm waiting...  :-)
Date: 22 May 2003 17:03:30
Message: <3ecd3b22@news.povray.org>
>   sqrt(pi * A) / pi
A is the emitter area, right?
Can you tell me about the origin of this formula?
> half bright.
Ehmm... can you explain more about this?
thx, sorry for boring questions.
         Manuel
Date: 24 May 2003 11:10:02
Message: <web.3ecf8a69a14066c984d065310@news.povray.org>
>>   sqrt(pi * A) / pi
Correct.
I solve it myself and it is based on basic geometry formulas. I also create
Cornell box scene to test it. Instrutions to Cornell Box scene are here:
  http://www.graphics.cornell.edu/online/box/data.html
It works. I can't explain better because my notes and files are home and I
have to use net from cafe until I get own Internet connection.
>> half bright.
Photographers use gray surface which reflects 18% light back to make
adjustments because it looks half bright.
  0.18^x = 0.5
  x = ln(0.5)/ln(0.18)
I'm not sure about this gamma. I'm still looking more information about
simulating camera and human eye dynamic range.
Matti
