POV-Ray : Newsgroups : povray.general : newbie question Server Time
28 Dec 2025 03:33:56 EST (-0500)
  newbie question (Message 1 to 5 of 5)
Subject: newbie question
Date: 29 Apr 2003 13:00:53
Message: <3eaeafc5$1@news.povray.org>
Greetings all,
	I have a simple problem I would like to cast before you all.
	How can I cut a plane (or a very thin and wide box) into
an irregular predefined shape?
	I have an irregular bounded flat shape composed of thin tubes and want
to fill the inside with a plane.  Imagine a distorted childs inflatable
paddling pool - I need to put the bottom skin in.
	I've been looking at the clipped_by and bounded_by directives but am
not making much progress.
TIA
nick
Subject: Re: newbie question
Date: 29 Apr 2003 15:05:07
Message: <web.3eaecbf2688f93ca0c272b50@news.povray.org>
@(none) wrote:
>Greetings all,
>TIA
>nick
If you can make a spline of your shape you can create a prism object, or if
you have the shape in a 2d image you could create a heightfield from that.
RG
Date: 29 Apr 2003 17:08:14
Message: <3eaee9bd@news.povray.org>
  Instead of using a plane, you could use a polygon or a prism. You can
shape their boundaries quite freely.
Date: 30 Apr 2003 07:41:48
Message: <3eafb67c$1@news.povray.org>
Thanks for the tips - ran out of time so I had to do it the hard way
by rebuilding the shape from scratch.. :(
cheers
nick
Date: 2 May 2003 15:23:29
Message: <3eb2c5b1@news.povray.org>
none wrote:
> Greetings all,
> TIA
> nick
you could use trace, from the center of the bottom skin to
points around the rim, and make a union of sphere_sweep's
from the center to every point on the edge (yes, it's sick :-)
Bill Hails
